01-09-2010, 04:00 PM | #1 |
Grandpa in the rustmobile...
will ignition from 69 c40-50-60 fit 68 c10
I think my ignition went bad..not sure...It'll run if I hold it from behind. The inside of truck stinks like burnt/bare wire/metal. I may try to tighten it up. There is a 69 (biger than c30) in the field. Will ignition switch fit my truck? And can I swap tumblers so my doors/ignition key is the same?
Thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-09-2010, 04:21 PM | #2 |
Re: will ignition from 69 c40-50-60 fit 68 c10
Yes they should interchange & the tumbler should fit. Usually when they do that the connector & main wire is usually burnt also. They have repair pigtails available at a parts store or you can cut the bad part off & use a crimp connector.
01-09-2010, 08:29 PM | #3 |
OH SO THATS WHAT THE GUY MEANT AT ORIELLYS ABOUT A PIGTAIL!!!
The ignition off the big truck didnt have a key and therefore I couldnt get the tumbler out.. Is there a way to get it off without taking tubler off? Will they have the pigtails in stock generally? Thanks!
01-09-2010, 08:52 PM | #4 |
The Older Generation
This thread might help with the no key situation... http://67-72chevytrucks.com/vboard/s...d.php?t=379745 LockDoc
01-09-2010, 08:54 PM | #5 |
what if i dont have the key to turn the tumbler though?
01-09-2010, 09:13 PM | #6 | |
LockDoc
01-09-2010, 09:37 PM | #7 |
Ok doc thanks I misread it.
Found a key to fit in it. But could not turn it. It was REALLY cold i sprayed with with wd40. That didnt help. Then I did something stupid I dont wanna say it but I was mad.... I saw a screwdriver...and, well you should get it from there..
01-09-2010, 09:53 PM | #8 | |
LockDoc
01-09-2010, 10:03 PM | #9 |
I should find one. Junkyard is next..
So theres no hope huh. Dang Yup, my mom used to tell me that alot...patience is a virtue...Must've missed out on that one. I should be able to get one. I may fool with it when it warms up. Not sure how far I tried to job the screwdriver in it... Oh my....
