Old 01-09-2010, 09:42 PM   #1
mike16
72 c10/307 lower radiator hose question
I'm trying to install the lower radiator hose in my truck. the hose is a Carquest Gates pn 20694. its a moulded hose.the problem is the way its routed it runs across the top and inner side passenger side frame rail. at this point it rubs and colapses the hose to about half its diameter.
anybody else have this problem
who else makes a hose for this application.
mike16 is offline   Reply With Quote
Old 01-09-2010, 10:01 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 72 c10/307 lower radiator hose question
The web site I found for that hose # says "cut to fit" for a '72 Chevy.
LockDoc
Leon
Old 01-10-2010, 07:35 AM   #3
stevewhitmore
stevewhitmore's Avatar
I have the same set up and I had to cut about 2 inches off at the motor to stop it from kinking up
stevewhitmore is offline   Reply With Quote
Old 01-10-2010, 11:01 PM   #4
timski69gmc
timski69gmc's Avatar
I have a similiar issue on my 69. Doesn't kind the hose as much, but the frame rail bends up there, and I am waiting for it to cut through the hose. Except for some plastic tubing wrapped around the hose, don't have a solution.
timski69gmc is offline   Reply With Quote
Old 01-12-2010, 10:05 PM   #5
brn agn
brn agn's Avatar
I have the same issue with the 307 in my truck. I bought my hose from Napa. I cut several inches off the water pump end. It helped, but it is still brushing up against the frame. My solution was to take the old water pump hose, cut it down, slit it down the middle and lay it in between the frame and the new hose. I would rather it wear through the old hose and not the brand new hose.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 01-12-2010, 10:19 PM   #6
timski69gmc
Thanks brn agn. Glad to know I wasn't the only one. If the frame at least wasn't bent up at that spot, it would probably be okay. I have even tried a flex hose, with simiiar results.
Old 01-13-2010, 08:16 PM   #7
mike16
maybe if I hit a tree with that side of the truck.....or as another owner pointed out try puttin it on correctly....I was trying to install it bass akwards. it looks like it should fit the other way.
Old 01-13-2010, 10:16 PM   #8
timski69gmc
Tried that. Well, not the tree part.
