Old 01-09-2010, 09:53 PM   #1
1971ls1longbed
1971ls1longbed's Avatar
ls1 in my longbed
i am putting an ls1 in my 71 and i am using the gm performance parts carb conversion kit using the front mounted distributor. i need to know if anyone has used this set up and if so how did u mount ur power steering and and alternator.
1971ls1longbed is offline   Reply With Quote
Old 01-09-2010, 10:16 PM   #2
1971gmcshortbed
1971gmcshortbed's Avatar
Re: ls1 in my longbed
Hi have you seen the controllers GMPP makes for the LS1 for carb applications? It uses the cank position sensor to fire the coils, less moving parts. I have never seen anyone use the distributor setup. I believe you use a ford dist.
1971gmcshortbed is offline   Reply With Quote
Old 01-09-2010, 10:28 PM   #3
1971ls1longbed
yea it uses the sb ford distributor i was going to try to find out if it moves the balancer out. if not im going to use a custom billet specialties kit to do it.
Old 01-09-2010, 11:30 PM   #4
ed2552
ed2552's Avatar
I would use an MSD box for it. DIS is way more accurate, and it will give you tuneablility with a laptop, as well as better fuel mileage, and economy. By the time you buy a distributor, front cover, and everything else needed, you'll have the same money invested as a cheap laptop and the MSD DIS kit.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 01-10-2010, 12:38 AM   #5
Strut
Strut's Avatar
If you search for HorsepowerTV episodes, they done a carb and distributor setup on a LS1 and put it on a engine dyno. Produced alot of power....
http://www.powerblocktv.com/site3/in...10&ep_sea=0901
There is the link.... They show a picture of it too. Looks pretty awesome! Would love to do it in mine, but thought it was quite expensive.
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 01-10-2010, 02:27 AM   #6
67ss&99ss
Andy
I watched that episode as well. They made 490 hp with the conversion kit and a comp cams thumper cam. The kit makes cam swaps about as simple as a regular SBC. I was surprised at how much power it made.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 01-10-2010, 11:12 AM   #7
Strut
Strut's Avatar
Yeah in made alot of power, but you got to take into account the serpentine belt setup or what ever you run. It will take some hp off the motor....
1972 Chevy C10 SWB
2008 Yamaha R1
Old 01-10-2010, 01:30 PM   #8
1971gmcshortbed
I dont think you can use a regular LS water pump either..
Old 01-10-2010, 01:43 PM   #9
Strut
Strut's Avatar
On the show they used a Electric Water Pump w/ water pump Spacers from Wagner....
The Distributor is from a 302 Ford....
If you have Itunes on your computer, you can download the full Episode and they tell you word for word what they used....
1972 Chevy C10 SWB
2008 Yamaha R1
