01-09-2010, 11:32 PM | #1 |
1 ton 4x4
looking to build a 4x4 dually flatbed need input and pointers on it what to start with what to use
01-10-2010, 05:19 AM | #2 |
Junior Member
Re: 1 ton 4x4
best bet is a camper/motohome. those are the extended chassis models and 1 ton dually.search here,someone just got one cheap. a bit of work to remove the camper and clean up the rails,and its ready for a bed. might have to fill the back cab wall,but if you can do the rest,that shouldnt be to hard.
http://67-72chevytrucks.com/vboard/s...ight=motorhome
67-72 Truckless for the moment Member# 1126 The one that got away http://customclassictrucks.com/featu...001/index.html |
01-10-2010, 11:28 AM | #3 |
Re: 1 ton 4x4
I would buy a 77-91 (88-91 old body style) 4x4 dually to start with. I would buy one with a flatbed already on it then I would put a 67-72 cab and clip on it.
I am working on an '86 myself. It is a regular cab with a shop built flatbed with recessed gooseneck hitch 454 SM465 205 Dana 60 front Dana 70 rear Hydroboost Oil Cooler and on and on. I gave $1800 for it. No way can you buy all these parts separately for that. So get one of these and do a cab swap.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 01-10-2010 at 11:29 AM. |
01-10-2010, 11:39 AM | #4 |
Re: 1 ton 4x4
look through the 4x4 builds. someone built a K-30 dually with a newer 80's frame... looks sharp.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
