01-10-2010, 09:42 AM | #1 |
drop or cross member vs z'ing frame
Is one way better than the other?Found a shop i'm going to check out his work,but he told me he has never done a dropmember install but what he would do is z the frame.But for some reason my spidey sense is telling me no.
01-10-2010, 09:47 AM | #2 |
Redefining LowBudget
Re: drop or cross member vs z'ing frame
subscribbed....I would go with a drop memeber ..theres probably a bunch of reasons but I would think a bolt in DM has to be easier to put in ???
01-10-2010, 12:10 PM | #3 |
if ya got the cash i say DM... if not then Z-ing is the way to go IMHO
Adam M STX Designs Motorcycles | Choppers | Hotrods |
01-10-2010, 02:40 PM | #4 |
The DM. is the wave of the Future...Seriously,Its worth every penny.Look into what the DM offers and weight it against the Z.
You'll know what to do. |
01-10-2010, 03:33 PM | #5 |
Junior Member
I did a Z because it didn’t cost me a dime. Had some scrap metal lying around and did it myself. I would likely get a DM if I was going to pay someone to Z. DM has so many benefits and if I wasn't on a shoe string budget I would have bought one. Rack in pinion, narrowed track width, wheel centerline corrected, weight reduction. Plus it just looks badass!
01-10-2010, 08:06 PM | #6 |
i would z for the dif in money if you go with drop member you will be sorry when you try to sell your truck putting $3500 to $4000 in your front cross member is not so smart when you think of what these trucks are worth
01-11-2010, 12:48 AM | #7 |
I say dropmember. I pulled my old x-member out and installed my dropmember in a few hours by myself in my garage. There is no telling how much the labor cost would be for a Z'd frame. I spent about $1700 on it including rack and pinion, swaybar, and steering linkage. It will center your wheels in the fenders and narrow the track width so you can ride lower without tire rubbing issues.
01-11-2010, 03:59 AM | #8 | |
a z only has a cost benefit if you have the know how and tools to do it yourself |
01-11-2010, 04:19 AM | #9 |
drop member you know what you getting no matter what.. who knows what a shop will do... i seen some hack jobs. it just makes sense to buy something that bolts on...
01-11-2010, 11:57 AM | #10 |
Happy to be here
I don't feel it should be a comparison of one vs the other. If you can't afford the Dropmember, then wait till you can. If you have the fab skills to do a Z correctly, you can probably earn the money to buy a Dropmember.
If you don't have the fab skills to do it correctly, you shouldn't be considering it as an option. If you can't do it yourself, and you have to pay someone to do a Z, you would be better off buying a Dropmember.
01-11-2010, 12:17 PM | #11 |
low n' slo
if i had the cash i wouldnt even consider a z over a dropmember. BUT, if you can do a z...then why not do a z. there is nothing wrong with it. personally, if you can afford it and/or the time saving up for one, then wait on the dropmember. it just looks so much cleaner
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
01-12-2010, 02:47 AM | #12 |
Thanks everyone never doubt the 1st mind...
01-12-2010, 03:55 AM | #13 |
The drop member is a bolt on besides welding in the notches for the tie rods.The price is cheap really a rack and pinion for these trucks is 3k.
01-12-2010, 03:56 PM | #14 | |
$3500 to 4K is not required to install one of these front crossmembers. If you opt for the full a-arms & such, it could be that much. But the c.member w/later model a-arms can & has been done for 2K (give or take a few hundred depending on your ability to find needed parts @ decent prices).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-12-2010 at 03:57 PM. |
01-13-2010, 12:20 AM | #15 |
And the dropmember was designed to narrow the track width and centers your wheels in the wheel wells.If you use your stock a arms and a used rack you could pull it off for 2k or less.
01-13-2010, 11:05 PM | #16 |
Ok one more ?Just how much involved is the dropmember?Besides the frame notch what more has to actually be done?Or is it really truly unbolt the stock unit notch and bolt in the dropmember button it all back up and your driving?
Flowershop Hip Hop & Street Rods Dropmember 83 Custom Deluxe Almond on Almond 85 Silverado White on Red/Now Chevy LeMans Blue Rendering in Truckin magazine vol 36 no. 11,2010 |
01-13-2010, 11:58 PM | #17 | |
It's best to have the drivetrain out of the way whether you Z or do a Dropmember. The c.member itself is a true bolt in deal. The holes that originally were used for the OE c.member locate the DM. They need to be drilled up one size but that's about it. You'll need to purchase a R&P set-up either from your local auto parts joint or from Summit, Jegs, etc. You'll need the appropriate steering parts (shaft, u-joints, & idler if necessary). The tranny c.member gets relocated because of the motors now slightly elevated position so it requires some holes to be drilled after determining where it needs to be (each application is different so there's no 'exact' to this step). The install can be done w/o welding the frame for the notches if you don't have the required gear. It would need to be trailered to your local welder to burn them in. Most vehicles require swapping from the engine driven cooling fan to electric; some won't (Dino's green truck uses the engine driven fan). That's about the jist of it. I recommend contacting Nathan & ask him any questions you might have. He's listed many p/n's & info & could help you regardless of your decision.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-14-2010 at 12:01 AM. |
01-14-2010, 12:21 AM | #18 |
Thanks again Scoti.I have spoke with Nate i just wanted to get some feedback from people that may have done this already,seeing that i'm new to all of this.As bad as i would like to have it it may be a lil more than i'm looking to take on myself.
01-14-2010, 07:38 AM | #19 |
You could start with a simple bag and tubular control arms for the front.And later if you want to get the dropmember depending which front bags you get you can reuse it all.
01-14-2010, 11:02 PM | #20 |
African-American Shaolin Monk
The DM only works with one style tubular arms,is this correct ?
01-14-2010, 11:11 PM | #21 |
The original versions worked w/6x-87 a-arms. Current versions work w/PB, Ride Tech, or 73-87 a-arms.
