Old 01-10-2010, 10:42 AM   #1
doug70
th350 to nv4500 swap
ok, I think I have a plan for the trans.
1993 NV4500, 1993 bellhousing with passenger side slave, clutch and brake pedals from 93, flywheel from 93, new clutch,pp,flywheel,pilot bearing
1971 NP205 8 bolt style(racetrack)
1983 TH400 to NP205 adapter with integrated mount and new special gasket
rebuild np205 and machine for large bearing, install 32 spline input shaft
Put it all together and hope for the best. I have read there may be some driveline clearance issues with the passenger side slave, but not everyone has experienced this problem. I will have to deal with that if it is a problem.
I expect it will take driveshaft modification.
Btw this all goes in a 71 k20.
Did I miss anything?
Doug
doug70 is offline   Reply With Quote
Old 01-10-2010, 11:32 AM   #2
duallyjams
duallyjams's Avatar
Re: th350 to nv4500 swap
Finding a nv4500 is the hard part everything is down hill from there.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-10-2010, 11:43 AM   #3
msgross
msgross's Avatar
advance adapters make a conversion kit.. a few members have the nv4500/205 setup
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-10-2010, 12:28 PM   #4
doug70
Thanks, I found a 93 donor truck, that's why I mentioned all 93. I would prefer 96 up, but like you said they are hard to find. My biggest doubt is the th400 adapter on a nv4500. I have seen the 86 up np205 with the th400 mount right up, that's why I think it will work.
Doug
Old 01-10-2010, 04:00 PM   #5
yellow70GMC
yellow70GMC's Avatar
IIRC the NV4500 bolts up directly to a np205 with the long 32 spline input, and the 6 bolt pattern, thats why the 86 up 205's that came with th400s bolt right up.
yellow70GMC is offline   Reply With Quote
Old 01-12-2010, 10:57 PM   #6
hatzie
Moderator
hatzie's Avatar
I thought the NV4500 output shaft needed to be shortened to fit up a NP205.
Not modding my $1100 NV4500 was the main reason I went with the 208. The brand new 208 for $180 was the other reason.
Old 01-13-2010, 06:58 PM   #7
yellow70GMC
Maybe so. I was talking about the input shaft on the NP205. Early NP205s with a TH400 had a short 32 spline input shaft, 1986 and later model NP205s had a long 32 spline input.
