PooP
![]() Join Date: Sep 2008
bag question?
does anyone have any pics of where they ran there front air lines after they come out of the bag. where is the best place to run the line through the front crossmember. thanks
GM ONLY BABY!!!
Re: bag question?
You should post this in the Suspension section. You would get more respones, or search the suspension section. Drill hole in spring perch with step bit, and use a rubber grommet. I ran mine pointing to the rear of the truck along outside of frame by the shock and then thru a hole in the frame to the inside of the frame. My truck is in winter storage so I can't get a pic.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
It'd be alot cooler if you did
Re: bag question?
PooP
Re: bag question?
thanks for the replies
![]() Join Date: Sep 2002
Re: bag question?
Here's mine.
I went straight up from the front bag, then curved in and through the frame. I then clamped the hoses along the frame over the crossmembers to the valve manifold at the rear. |
