01-26-2003, 09:40 PM | #1 |
reumster Rules. check this out!! (cargo & third brake light in one)
Ryan has made this sweet Cargo light insert. When the your cargo light is off and your foot is not on the brake, the cargo light looks completly stock. You cannot detect that anything has been done.
However, when you turn your cargo light on, the light is about 3 times brighter then stock and way whiter. Then when you put your foot on the brake the light is a brilliant red. Here are some pics. This is the best and most satisfying modification i have yet done to my truck and consistent with the whole modification philosophy on my truck. Keep it mostly stock in appearance, keep it simple .. but make it trick. here is a pic with the cargo light on |
01-26-2003, 09:41 PM | #2 |
now here is the same cargo light when the brakes are depressed
01-26-2003, 09:48 PM | #3 |
here's how you hook it up
the insert has a standard bulb on it for the cargo light. all you do with this is put it into your cargo light socket in place of the stock bulb. the insert also has a positve and negative wire off of it. You will see that i have used a stock gm connector to hook the postive wire to a green wire that runs along with the stock dome light wiring to under the dash. I will show you where to hook this in in the next picture. the negative (black wire) just goes to groud, I ran this wire with the stock dome light wiring and put a spade connector on the end and used the screw that holds the high beam swith to the floor to ground the connector to the body. the wiring is very simple and easy to do. (took me about 15 minutes!! Last edited by 1971short4X4; 01-26-2003 at 09:59 PM. |
01-26-2003, 09:51 PM | #4 |
here is the underdash connection. The mess under my dash makes this look more complicated then it is. One connection must be made! All you need to do is use a splice connector (in blue in the pic) to connect the postive wire (in green in the pic) to the stock white wire coming off the brake switch. With this connection when you put your foot on the brake, the postive wire is energized to get the red leds in you cargo light housing to turn on.
01-26-2003, 09:56 PM | #5 |
Fyi,
this truck did not originally come with a cargo light. So for all of you that like what you see, you can easily add the stock cargo light housing to your truck. (i think the truck shop in orange ca, sells the stock cargo housing for 30.00.. you will also need the lens and the screws... which i believe they have). Point is this mod is Sweet and I love it so much i'm going to do it to my red 1971 4X4 truck. Ryan and custom classic LED's RULE. Please let me know if you have any questions. I have the original instructions that tell you how to make the hole in the cab to put the cargo light in. If you place an order with Ryan, or joel I would be happy to get this information to them, so that i can be included with the insert. I took this to the pomona swap meet last weekend and about 20 guys with these trucks wanted one! thanks Ryan tom |
01-26-2003, 10:27 PM | #6 |
Thats cool, is the brake light very bright looks kinda dim?
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
01-26-2003, 10:39 PM | #7 |
L.E.D. Freak
Wow Thanks Tom. You tired from all that typing? You better take a nap! LOL
crazy4chevs The LEDs I used are the same LED used in our tail inserts with brakes applied. And the insert Tom has uses 84 LEDs! The picture most likely isn't justifing the brightness. So trust me it's bright! These inserts are the Deluxe, Top of the line version. Maybe Tom can get a picture of the board itself. I make third brake light/Cargo inserts, as I get an order.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
01-26-2003, 10:45 PM | #8 |
KEEP ON TRUCKING
sweet i will be checking with u in near future
72 cheyenne 2wd lwb 71 k20 sons bassett va |
01-26-2003, 10:58 PM | #9 |
Could this be put in the FAQ section? Save me from searching for it when I get to this project.
01-26-2003, 11:32 PM | #10 |
just so everyone is clear. the red lights for the 3rd brake light are very very bright. The funny thing is they are really elusive and difficult to take a pic of. (a digital camara, makes them look pink, and a regular 35mm camara makes them look red but dim)
Trust me though they are very bright. I will post a pic of the insert later, for those that would like to see it. tom |
01-27-2003, 01:11 AM | #11 |
Very cool!
I've been thinking about doing that for about ten years but never put any effort into it. Thanks for making it easy.
'71 Cheyenne Super '80 Custom Deluxe '75 Blazer |
01-27-2003, 02:19 AM | #12 |
ttt
01-27-2003, 06:27 PM | #13 |
Excellent idea..........
and thanks for sharing the info with everyone.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
01-27-2003, 06:37 PM | #14 |
SLOW BUT SURE,BUT CLOSER
I guess I'll have to get one!!!!!!!!!!!!! Sweet!!!!!
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
01-27-2003, 07:08 PM | #15 |
nice
01-27-2003, 10:29 PM | #16 |
L.E.D. Freak
Thanks to all for comps! For right now I have to make these by hand. Because not to many people have Cargo lights to justify production. I'll have picture soon of the 3 models I can make.
01-27-2003, 10:38 PM | #17 |
How much does something like that run? Because, it's pretty sweet!
01-27-2003, 10:47 PM | #18 |
L.E.D. Freak
racedvl Look at the other cargo topic. I can make 3 different styles of the cargo insert.
01-27-2003, 11:03 PM | #19 |
Sweet!
01-28-2003, 02:23 PM | #20 |
Very sweet Reumster!
I'd be interested in one.
Zurbo's Chevy - 1972 Black/White Cheyenne Super. 402 Big Block /THD 400, factory air and tilt. My other Chevy - 1998 Camaro SS |
01-29-2003, 09:52 AM | #21 |
L.E.D. Freak
Zurbo
And others wanting them. Let me know. If you want one e-mail me direct. And let me know what stage you want.
01-29-2003, 12:13 PM | #22 |
UK Wildcat Fan!
hello Reumster, what do you mean there are three types (stages?). I would like one, I'm at the 'painting the frame' stage of my project :-)
01-29-2003, 05:18 PM | #23 |
L.E.D. Freak
On 1st option is just RED LEDs third brake conversion. 45.00
2nd is 12 White LEDs, and 54 RED LEDs cargo and third brake 75.00 3rd Maxiumum LEDs 24 White 84 RED 110.00
02-04-2003, 01:01 AM | #24 |
Ryan
i just bought a set of your rear tail light inserts from tom and they kick @ss. ive seen your cargo light insert in person and it rocks. i have also seen the cargo light third brake light combo and i want one. keep the good stuff comming. thanks bob |
02-04-2003, 07:06 AM | #25 |
L.E.D. Freak
Thanks sano_surfer
Did you see the Caddy inserts yet?
