Old 01-10-2010, 07:12 PM   #1
69c10step
69c10step's Avatar
Need fuel line help quick
I need to know what size the rubber hose is that is between the bottom of the tank & the steel line - it is about 12'' long. Mine is dripping gas all over my driveway as I type this.
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 01-10-2010, 07:20 PM   #2
JimKshortstep4x4
Re: Need fuel line help quick
It could be 5/16" or 3/8" hose. It depends on the engine size that you have.
350 ci and larger engines came with 3/8" gas lines.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-10-2010, 07:20 PM   #3
cdowns
cdowns's Avatar
depends on weather you have 5/16 or 3/8 steel gas line //measure to see wich you have
Old 01-10-2010, 07:23 PM   #4
brn agn
brn agn's Avatar
As already mentioned...5/16" line if was originally a 6 cylinder truck or V8 with a 2 barrel. 4 barrel V8's got a 3/8" line I believe.
If you need it fixed immediately, buy 12" of both sizes. You may want to pick up some small hose clamps while you are at it.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 01-10-2010, 07:24 PM   #5
69c10step
69c10step's Avatar
originally a 6 cyl., now a V8. My best bet, I guess, will be to by one of each and see what fits. Thanks guys.
