Old 01-10-2010, 08:10 PM   #1
longbedrick
longbedrick's Avatar
what's a marine engine?
what makes a "marine" engine different than a regular block?
longbedrick is offline   Reply With Quote
Old 01-10-2010, 08:13 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: what's a marine engine?
marine engines are made for the boat car engines are made for the car...some marine engines turn the opposite way of an automotive engine if memory serves correct
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-10-2010, 08:17 PM   #3
3r!c84
Badass
3r!c84's Avatar
yes.my buddy truck has a marine engine.that spins backwords
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-10-2010, 08:18 PM   #4
cableguy0
The main difference is the camshaft. freeze plugs are brass. water pump impellor is brass. there are minimal differences. as stated some are reverse rotation which you wouldnt want.The cam used in most boat engines is a terrible cam for a street cam mainly due to operating range but its not a deal breaker.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-10-2010, 08:20 PM   #5
dooce
Can someone explain how this would work?
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 01-10-2010, 08:25 PM   #6
cableguy0
It wont.... the 3 forward gears would become reverse gears. its not possible
Old 01-10-2010, 08:25 PM   #7
3r!c84
Badass
3r!c84's Avatar
you gotta drive in reverse lol nah he just fliped the axel over so it would run backword (im not 100% sure,i forgot what he said he did)
-00 Saturn 5spd
1/4:13:90
Old 01-10-2010, 08:35 PM   #8
Chlsnk
Chlsnk's Avatar
Also the flexplate is different.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 01-10-2010, 09:14 PM   #9
80SPORT
80SPORT's Avatar
The Chevrolet marine engines are very similar to the pre emission truck engines....and the GM Performance parts engines.We are a Mercury dealer and have installed marine engines in Camaros and pickups with excellent results.One advantage of the marine EFI is that it is stand alone ....no oxygen or speed sensors to hook up.
As mentioned elsewhere the marine engine comes with brass components in the cooling system;for this reason we do not suggest using automotive engines in boats that will see salt water.
The reverse rotation motors were used in some direct drive ski boats and one side on twin engine direct drives;they were discontinued in 87 when the 1 piece rear main seal came in.
80SPORT is offline   Reply With Quote
Old 01-11-2010, 12:18 AM   #10
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Cams are different and the firing order is backwards. The starter and flexplate are made to work backwards. I would assume that the dist gear is also different. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-11-2010, 12:46 PM   #11
454HO
I'v known lots of people that ran a marine cam in a street car. I myself have a marine cam in my L-29 Vortec big block motor. There is nothing terrible about it. It is much better than the factory cam that came in the engine, and it is a true billet roller cam. Likewise, there are lots of marine engines out on the waters that run so called street cams.
The issue with cam timing in a marine application is the exhaust valve closing event. You want to make sure the exhaust valve is fully closed before the piston goes too far down on the intake stroke (ie little overlap). Otherwise, it can suck water in from the exhaust. This is reversion, and if you are not carefull with cam selection you may end up hydro-locking the engine. Other than this, and the above mentioned reverse rotation engines, there is nothing unique about cams used in marine applications.
Cam lift, duration, lobe seperation, etc are all spec'd with the intended operational parameters of the engine. Marine engines need a lot of low end torque to get the boat moving and up on plane. And they typically have cruise rpm range much higher than an automobile engine. Therefore factory marine spec cams typically have a wider LSA to get a broader torque curve. But again, there is nothing terrible about that for street use. In fact, it is very similar to the popular RV cam grinds.
- Greg
454HO is offline   Reply With Quote
Old 01-11-2010, 03:02 PM   #12
SSC's76
No No
SSC's76's Avatar
Theres nothing magic about making an engine spin backwards it just requires a cam gound in reverse or installed 180* out an oil pump with reverse gear set and means to kick the engine over in the oposite direction. As long as you have a mount point for the starter, replace the oil pump and cam a reverse rotation engine is no different.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 01-11-2010, 09:43 PM   #13
turbo350
The 305 in my boat is not very different than an automotive 305 of the same year. Its rated at 225 hp which is a bit more than the automotive 305s of that year. Big difference is the cam of course which is similar to an RV grind. Not sure on the heads, I'd have too look at the numbers again but this is a '78 so its likely smog style heads. Boat engines work twice as hard as a car engine so they need the power down low. The only other real difference on mine are the marine grade head gaskets and the marine grade starter. I run an automotive Holley carb. This engine if put in my truck would run just fine.
turbo350 is offline   Reply With Quote
Old 01-16-2010, 08:36 PM   #14
2bits
2bits's Avatar
I put a Mercruiser 250 Inline 6 in my '71 truck, it spun the "correct" way and ran great with good low end torque and just fine on the freeway. Same block, just built better, just make sure it's one that turns the right way
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 01-16-2010, 08:43 PM   #15
78-5.3
78-5.3's Avatar
arent most reverse rotation engine fitted to boats with 2 engines to stop the boat from wanting to go in circles and pull straight????
78-5.3 is offline   Reply With Quote
Old 01-16-2010, 10:23 PM   #16
3r!c84
Badass
3r!c84's Avatar
Yes... they are also some Honda motors that are reverse rotation motors
-00 Saturn 5spd
1/4:13:90
Old 01-17-2010, 08:21 AM   #17
LONGHAIR
It's not about "going in circles", it's about efficiency.
With 2 props running the same direction, and placed side-by-side, the water that "exits" the props "fights" with itself. So there isa bunch of thrashing but no thrust...
With counter-rotating props, the water is moving together and in the same direction.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-17-2010, 09:43 AM   #18
4x4toy
If you convert a reverse rotation marine engine to standard rotation engine you will need to change-
camshaft,distributor,oil pump,starter motor,rear main/front crank seals,(yes these are different) and flywheel.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 02-02-2010, 12:11 PM   #19
McMurray76
The BBC in my boat does run "backwards", the top half (cam, distributor, oil pump) runs forward though. This is done with a special cam and timing set. Instead of a timing chain on two gears the gear on the cam meshes directly with the gear on the crank reversing the direction of rotation. This could be easily modified to run in a standard rotational direction. Hope I helped and not hindered.
McMurray76 is offline   Reply With Quote
Old 02-02-2010, 12:44 PM   #20
87Bob
With a reverse rotating engine. OH just think of the fun you could have. What a wild mid engine off road buggy/sand drag buggy /mud bog buggy you could build. Perfect weight balanced! YEEEEEHAAAAA!!!
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
