Old 01-10-2010, 11:34 PM   #1
dabruce15
dabruce15's Avatar
Should I just find a doner cab to fix this???
Whatcha think?
dabruce15 is offline   Reply With Quote
Old 01-10-2010, 11:44 PM   #2
JimKshortstep4x4
Re: Should I just find a doner cab to fix this???
It looks like damage that a good bodyman could fix. Have you asked anyone to look at it?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-11-2010, 12:21 AM   #3
dabruce15
dabruce15's Avatar
I haven't had a professional look at it yet.
Old 01-11-2010, 12:23 AM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
if its a clean rust free cab id try to fix it lol.
but your in CA should be a good cab layin around in great shape headed for the scrapyard as I speak LUCKY
John
1999 Toyota Tacoma 4x4
Old 01-11-2010, 12:23 AM   #5
Sublvr72
Sublvr72's Avatar
it can be fixed, but that's gonna be a tough one. It might be cheaper and easier to get a new cab.
If not it can be pounded out from the inside, but most likely you will have to use a good amount of body filler to get it straight again.
Sublvr72 is offline   Reply With Quote
Old 01-11-2010, 12:36 AM   #6
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
That is a pretty easy dent to take care of. Much easier than cutting apart your cab for a corner, or worse yet, replacing your whole cab!
A good body man can get that out with minimal filler. Just leave it in primer until you are ready to repaint your truck.
Just my 2 cents.
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 01-11-2010, 12:36 AM   #7
dabruce15
dabruce15's Avatar
By donor cab, I mean to cut a patch panel. The passenger rocker has to be patched too. The rest is rust free.
Old 01-11-2010, 01:13 AM   #8
ace of shades
NEWBIE!!
ace of shades's Avatar
a body man could get that out. I don't know you abilities but a stud gun and slide hammer, or the old fashion way by drilling holes, putting a screw in style slide hammer (probably the way to go with actual metal, not the tin they have on cars now) and go that rout. Personally I could *(like I said I don't know your abilities)* get that out and use the same amount of filler, or less, than it would be to weld in a patch.
Welding in a patch would mean you HAVE to pull the tank for safety reasons, pull the back glass and probably the box. It could be beat out from the inside though. The major thing that would make or brake the decision would be your abilites
Water is for the weak
I don't like cocaine.. I just like the smell of it
"Well there might be a dime up a goats ass too, but I ain't looken" - Grandpa
VolksRods
ace of shades is offline   Reply With Quote
Old 01-11-2010, 04:32 AM   #9
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
I agree with the majority. Check around with some local body shops.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 01-11-2010, 09:45 AM   #10
dfwright
dfwright's Avatar
If you've got a good backup plan in a new cab, you've got nothing to lose by trying first to see if you can get it out.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-11-2010, 09:59 AM   #11
suville
suville's Avatar
Beating that out from the inside isnt really a good option thats a double wall. As has been stated any qualified body man can repair that without breaking the pocketbook and you wont compromise the integrity of the cab that way plus if you need to replace rockers as you indicated it will channel the funds needed in that direction.
suville is offline   Reply With Quote
Old 01-11-2010, 11:14 AM   #12
62ramptruck
I am working on one now that is MUCH worse than that. The cab had been hit by the bed in a rear end collision but the cab was very solid and good cabs are hard to find here.
A good stud gun, hammer/dolly, and some patience will fix that without issue. I do body work and fabrication for a living but any body shop can easily fix this at minimal cost.
1968 C10 SWB "Project Shop Truck"
1964 Impala 2DR Hydraulics
1933 Ford 2DR Sedan
1965 AC Cobra (Long Term Project)
1998 Viper GTS-R
1962 Chevy RampTruck (SOLD)
62ramptruck is offline   Reply With Quote
Old 01-13-2010, 04:46 AM   #13
harry
harry's Avatar
dents are always cheaper and easier to fix than RUST RUST RUST
harry is offline   Reply With Quote
