Old 01-10-2010, 11:52 PM   #1
extd56
extd56's Avatar
1969 Blazer transfer case
What transfer case and axles did GM use in a 1969 Chevy Blazer with a 350 engine and a 350 trans? Also what gear ratio would it be> Thanks
extd56 is offline   Reply With Quote
Old 01-11-2010, 12:42 AM   #2
Livrat
Member #1049
Livrat's Avatar
Re: 1969 Blazer transfer case
if its a T350 trans it should have a new process 205 transfer case.. the axles are a dana 44 drum brake in the front and a 12 bolt in the rear.. most common ratio was 3:08 with the optional one being 3:73..
Livrat is offline   Reply With Quote
Old 01-11-2010, 05:06 PM   #3
swyfor5
swyfor5's Avatar
My "70" came with a Dana 20 t-case behind a 4 speed manual.
swyfor5 is offline   Reply With Quote
Old 01-12-2010, 07:04 AM   #4
Blazer1970
Blazer1970's Avatar
But behind an automatic, it will be a 205.
Blazer1970 is offline   Reply With Quote
