01-11-2010, 12:37 AM | #1 |
Blower motor won't stop running Help
Hello I have had many old chevys like this. Where in the summer you open the hood and unplug the blower, but I want to fix this one. The truck i'm doing is a 78 1/2t 2wd. The fan control will not shut the blower motor off. I first off bought a new blower resistor in the heater box. That did not work, I have speed control now but it wont shut off. What do I try next?? The fan switch maybe??? btw no factory A/C
01-11-2010, 12:58 AM | #2 |
Re: Blower motor won't stop running Help
i think they'll all like that. maybe you could hook up an in-line switch to the blower. i dunno what much else you can do.
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
01-11-2010, 01:11 AM | #3 |
BAD BOW-Silverado XST
The fan is designed to run all the time. You'll have to install a bypass switch to turn it off.
01-11-2010, 01:15 AM | #4 |
seriously wow ok
01-11-2010, 01:16 AM | #5 |
does any one know why
01-11-2010, 01:18 AM | #6 |
78 Big10 454
I bought my 78 new in Dec. of 77. The salesman made a big deal of the blower being on constantly, calling it "Astro-Ventilation" or something of that sort. After 32 years, I'm used to it.
01-11-2010, 01:25 AM | #7 |
OK Thats really odd, Do you know where I can find anymore info on this.
01-11-2010, 02:39 AM | #8 |
haha, ford guys...
it runs all the time, chevys idea was to keep the heater core cool due to direct water pump-intake manifold hook up (not radiator hook up).... you can put an inline switch on it but make sure u use a beefy switch or a relay.
01-11-2010, 08:57 AM | #9 |
Yep....I got rid of this little "option" a long time ago.
Here is how to do it: You need to pull your dash bezel cover off, and unplug the harness from the fan switch. On the plug you will see I think a brown wire that jumps to 2 terminals at once. One of the terminals is the power to the switch and one is for the low speed, hence making the fan run all the time on low. You can cut that wire out - but be warned you will then only have medium and high speeds left. I don't care about low anyhow, truck is still cold in the winter on high ha ha.
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson |
01-11-2010, 04:07 PM | #10 |
Project Optimus Prime
my question is why would you even wanna stop it from running? its been doing it for years and hasent hurt anything, i dunno just my 0.02 i guess
84 SWB work in progress 89 burb 1500 (parts pig) LOL 08 ford focus (I know, I know) Wifes car "I said it b4 and i'll say it agian wiring is my worst enemy":devil: |
01-11-2010, 04:20 PM | #11 | |
Or are you saying it runs at a low speed (only when the key is in the "on" position) even when you think the system should be "off"? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-11-2010 at 04:22 PM. |
01-12-2010, 08:53 AM | #12 |
Way too hot in the summer for me.
01-12-2010, 09:27 AM | #13 |
I just clipped the yellow wire at the blower resistor to get rid of low. I didn't need low anyway. And to kill the heat in the summer, I put a manual shut off valve in the heater hose. Made it much better.
CHEVY ONLY |
01-13-2010, 02:16 AM | #14 |
The Blower shuts off when I turn key off. I just thought that it should shut off when I tell it to. Also Its not really needed when its 100 above with 85% humidity. Its hot enought just running around town. I just find it odd that is doesnt shut off. I thought every pickup I have had has this problems.
01-13-2010, 08:17 AM | #15 | |
I had a different problem: the blower was stuck on High no matter where I put the switch, and then remained running even when I shut the engine off and removed the key. I had to pull the power wire to the blower motor to keep the battery from running down. After doing this for a couple days it finally "healed" itself. There is a module mounted on the case that is suspect; I will replace that module first thing if it ever does it again. Thanks for the followup - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-13-2010 at 09:30 AM. |
01-13-2010, 08:27 AM | #16 |
01-13-2010, 07:43 PM | #17 |
on the note on the blower not turning off my blower doesnt work i pulled my blower and it dont spin freely also the fuse got really hot and blew could the fact its hard to spin make it not work and blow a fuse!!
01-13-2010, 08:05 PM | #18 |
6.0 powered square
yes
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
