Old 01-26-2003, 10:34 PM   #1
apstguy
LED King
apstguy's Avatar
My day with the H/VAC system
My entire day today was spent working on my truck. First, I washed it (wow it sparkles!!!) and then replaced my Voltometer from the one in the cluster I picked up from the swap meet. It works!!! The oil pressure doesn't though.. the sender must be bad or this gauge is bad too. I'll replace the sender next.
The demon H/VAC system was next. I took my dash off and ripped every hose & tube leading to a vent out. I left the core in (heater, A/C & fan) and found out why my system wasn't working right. There is a plastic arm that positions the main door that snapped. The only plastic moving piece broke (didn't doubt it would be plastic). My defroster didn't work very well and the vents stayed on when it was in the heater position. This will fix it. If you have the same problems I do, open your sytem up and replace this plastic @$%#. At least it wasn't a vaccuum diaphram.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 01-26-2003, 11:52 PM   #2
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
Cool. For a second I thought you ripped it all out and were going to leave it out. glad to hear you fixed it.. the hvac system on our trucks, even the old ones are pretty *****in when they are working correctly.
mike
mike reeh is offline   Reply With Quote
Old 01-27-2003, 02:14 AM   #3
ironwood
$640 truck// doesn't run
oil pressure gauge
I am new to this board, so Hi everyone.
As for your oil pressure gauge if you have to get one don't even try cause I have been told that chevy no longer makes the oil pressure gauge (new) anymore. If somebody knows where I can buy a new gauge let me know I have an aftermarket gauge and no light in it most of my driving is at night.
ironwood is offline   Reply With Quote
