Old 01-11-2010, 09:35 AM   #1
sub-urban72
Motor Mounts
Are the motor mounts on a small block 2 WD the same as on a 4 WD?
sub-urban72 is offline   Reply With Quote
Old 01-11-2010, 11:44 AM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Motor Mounts
If you are refering to the rubber parts that mount on the engine block itself... Yes..
Livrat is offline   Reply With Quote
Old 01-11-2010, 02:08 PM   #3
sub-urban72
Re: Motor Mounts
I should have been more clear. I was talking about the metal part that bolts to the crossmember
Old 01-11-2010, 11:33 PM   #4
Livrat
Member #1049
Livrat's Avatar
Re: Motor Mounts
4X4's are different than a 2WD as they use an engine cradle that the rubber mount bolts too..
