Old 01-11-2010, 01:11 PM   #1
Tony_SS
Tony_SS's Avatar
Question 2wd or 4wd? Can't decide.
So I'm still searching for a Suburban or Blazer. I've seen a lot, but none that were right for me. I thought if I decided on 2 or 4wd, that'd help narrow it down a bit.
I've never owned a 4wd square. Can they be costly to repair and upkeep? Does mileage suffer a lot? Here in mid Missouri, we dont see a lot of snow, so 4wd might be used a few times a year. I would like 4wd, but I think the cost may outweigh the benefit in my case.
Any feedback?
Tony_SS is offline   Reply With Quote
Old 01-11-2010, 01:15 PM   #2
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: 2wd or 4wd? Can't decide.
They aren't that much more to maintain, the routine maintenance goes up a little bc you have to deal with another axle and a transfer case. It gets really expensive when you want to lift it and do all that stuff to it.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-11-2010, 01:46 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Since you've already got the cool truck, go 4x4. They aren't really more difficult to maintain but there is more there to break. Unless you plan on really abusing it offroad, that's not a concern.
I'd love to have a square body 3/4 ton 4x4 Burb to park next to my Blazer, I'd like to have one of each.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-11-2010, 02:01 PM   #4
justpball
justpball's Avatar
i have both, love them both for dif reasons, dont think you could go wrong with either...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 01-11-2010, 04:01 PM   #5
Tony_SS
Tony_SS's Avatar
I'm thinking come spring/summer some 4x4 k5's and 'burbs will start to show up.
What do you all think a practical lift is / isn't?
I think 6" is too much... is 4" too much? I'll be dealing with putting kids in and out of seats so I'm thinking 2-3" max, if any.
Old 01-11-2010, 04:57 PM   #6
Conundrum
Conundrum's Avatar
A 4" lift looks good on these trucks with some 35s, but it would cause some difficulties with getting the kids in and out.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 01-11-2010, 05:08 PM   #7
Tony_SS
Tony_SS's Avatar
I'm thinking 2-3" with 33x12.50 on 15x10's. And I'm leaning toward a Suburban since it'd be more family friendly.
Old 01-11-2010, 05:15 PM   #8
sdailey
The Few, The Proud
sdailey's Avatar
Not a suburban or blazer but here is a shot of my old '87 with a 2" Rancho lift running 33 x 12.50's on 15 x 10 rallys. Maybe this will give you an idea of the "look" that the lift would give you.
Shannon
sdailey is offline   Reply With Quote
Old 01-11-2010, 05:21 PM   #9
Conundrum
Conundrum's Avatar
I totally agree with that.
Old 01-11-2010, 05:52 PM   #10
68Timber
68Timber's Avatar
A 2" to 3" lift over 33" tires on 15x10's looks great on the short wheel base pickups and Blazers (to me that's the "ideal" lift/tire combo) but the mammoth Suburban needs 4" of lift over 35" tires to get the same look. The easy way to keep the lifts cheap is to keep them small enough so you you don't need the driveshafts lengthened. You can lift a Blazer up to 4" and run the original driveshafts, I'm not sure how much you can get away with on the Suburban - probably the same as the Blazer since the front drive-shaft length will be the same but I'm not 100% sure.
John
74 Honda Z50 build
Old 01-11-2010, 06:14 PM   #11
Tony_SS
Tony_SS's Avatar
sdailey, that setup looks great!
BRUISER, I agree... that's the one drawback with the blazer/burb, is that is so top heavy that it does need a good foundation to balance out the top.
If anyone has a blazer/burb with a 2-3" lift 33" tires on 15x10's, I'd love to see it.
Old 01-11-2010, 06:25 PM   #12
rcbildr
rcbildr's Avatar
Here's my 85 4x4 burb with a 4" lift. I've driven 2wd and 4wd and I prefer 4x4. I like to go camping and fishing a lot and I like this set up alot. There's plenty of room to load up everyone and bring our dogs with us when we go camping. It is a pain in the butt lifting the kids (we have 2 girls ages 4 and 7) in and out (I have 3 torn disks in my neck) but I will eventually build steps so the kids can climb in on their own.
The specs are in my sig. If I remember right the rims are 15x8 and they are offset enough so I didn't have to do much grinding to get them to clear the front calipers.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 01-11-2010, 06:30 PM   #13
Tony_SS
Tony_SS's Avatar
^what tires are you running there?
I think I might want to stick with a 2-3" lift.. 4 looks like too much for my intended use. I like the look though!
Old 01-11-2010, 07:21 PM   #14
cochino12
It followed me home?
cochino12's Avatar
You already have a cool 2wd so I say get a 4wd, they are very easy to come by and lifts are super cheap and you can install them in an afternoon in the driveway.
4" lift and 35"s will still rub pretty good if you do any sort of off roading, how about a 4" lift and 33"s? That will get the truck sitting just a tad higher than a most new trucks come stock but still do just fine wheeling.
EDIT: I forgot, if you lift a blazer make sure you lift the rear at 1" more than the front or it will have a saggy rear
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-11-2010, 11:18 PM   #15
Tony_SS
Tony_SS's Avatar
thanks guys.. great info here.
Old 01-12-2010, 12:27 AM   #16
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Here's my blazer when I bought it. It had a 3 inch body lift with 35x12.5's on 15x10 wheels...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-12-2010, 06:20 PM   #17
rcbildr
rcbildr's Avatar
The tires are 33x12.50.15. Eventually I want to go with 35's.
My Projects:
1978 Camaro Z28
