Old 01-11-2010, 07:20 PM   #1
pro1955
pro1955's Avatar
1956 core support
I have the core support out of the truck, I was wanting to cut out the 2 cross bar supports that cross in front of the radiator. Will this cause any issues? I want to put a trans cooler in that area.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 01-11-2010, 07:54 PM   #2
blackdiesel
blackdiesel's Avatar
Re: 1956 core support
I cut mine out, and I've seen others that were gone also. I'm sure it's there for a reason. But we don't use our truck the way there were used back in the day, so I think were ok.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 01-11-2010, 08:07 PM   #3
Wildstreak
"something witty here"
Wildstreak's Avatar
oklahomaduner is building a 66 and they have the same thing in the rad supports, he just gusseted them for support. I would say thats what i would do. check his build out.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 01-11-2010, 09:44 PM   #4
OrrieG
OrrieG's Avatar
Originally it looks like they were used to keep the frame core support from moving out of squareand tweaking the radiator core causing leaks. That said I drove miine as a 4WD (see avatar I've had it much more twisted then that) with one of them broken off and did not have any problems. I got a new core support and kept them.
OrrieG is offline   Reply With Quote
