Old 01-11-2010, 09:03 PM   #1
AirSpeed
AirSpeed's Avatar
Rear bumper brackets, 4X4 versus 2 wheel drive
I just bought a brand spankin new Chrome rear bumper for $75 (bragging). It's going on my 72 GMC 4X4. I need to order rear bumper brackets. Some catalogs show brackets specific to 4X4 trucks, others show the same brackets for all. I measured the frame on my 69 C-10 and it seems the same as my 72 GMC 4X4. Is there a difference that I'm not seeing?
AirSpeed is offline   Reply With Quote
Old 01-11-2010, 10:30 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Rear bumper brackets, 4X4 versus 2 wheel drive
Yes, there are differences in the rear inner brackets. Some are designed for coil spring trucks and leaf spring trucks. Others are designed for swb and lwb. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-11-2010, 10:48 PM   #3
71 super
71 super's Avatar
The original 4x4 inners have a brace welded on the inside, they will look like an after thought or home engineering, but they are factory reinforcements. The swb 4x4 and maybe short gmc with leaf springs used these, the long wheel base 4x4 uses the same brackets as regular coil spring truck due to the location of the rear spring perches. If you want the bumper to fit correctly you need the right brackets for the swb. Wes at classic heartbeat carries them as does GMC Pauls as well as others. You will spend as much for the right brackets new or used as you did for your bumper. Hope this helps.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
