I need a tranny
Hey,
In my jim i have a 454 with a 4 speed granny LOW with a np205 and 373 12 bolt axles. Down the highway with 37 inch tires, Im at about 2800 doing 80 KM's... I really dont need the low gear since I dont wheel the truck that often so im just looking for some better fuel economy and so I can go abit faster on the highway. I really dont want to change hte gearing in my differential. What kind of 5 speed transmissions are out there? Would this solve my problem? I have a 700R4, but whats the fun in that ![]() thanks -Rhys ![]()
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
Re: I need a tranny
An NV4500 conversion would be your best bet. It's a much like the SM465 you have, but with a 5th gear that's overdrive. It's tough enough to handle a 454.
1977 GMC Sierra Grande |
Re: I need a tranny
Yea i was looking at nv4500, id love to get my hands on one. Impossible to find! i found one the other day but 2 grand? way out of my budget, any cheaper alternative?
BAD BOW-Silverado XST
Re: I need a tranny
If you don't abuse it or tow over 5000 lbs, a NV3500 will survive. You can easy rebuilt one yourself.
Re: I need a tranny
What is 80 kmh? I only know mph, but with thos tires and rear end 2800 rpm should be at least 60mph.... 2800 rpm is the sweet spot on the highway if its hilly too.
1982 K10 SWB 1987 V20 - Sold - Doh! |
Re: I need a tranny
80km's is 50 miles
Re: I need a tranny
a nv4500/3500 or ranger overdrive giving you 8 gears and about the same money as a good nv4500
Re: I need a tranny
You should be turning less Rs than that at 50 mph. I have close to the same setup as you but with 35s and 4.10s, turning about 2800 at 70. Check this site out, good info for gears and such...www.4lo.com.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS Last edited by b454rat; 01-11-2010 at 11:21 PM. |
Badass
Re: I need a tranny
Hoffman65burb: I have a 700R4, but whats the fun in that
![]() yeah your right you should let me have it then ![]()
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Re: I need a tranny
Is that a block I see IN THE FRONT AXLE?!?!?
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
Re: I need a tranny
Not to get off topic but what does your rear window sticker mean it sure looks like a cool design. And your truck is so clean!
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
#13 |
Re: I need a tranny
#14 | |
Re: I need a tranny
![]() hahaha, just till i can afford some 35's, was just to clear the 37's to play in the mud abit it was a 4 inch lift with 33's, gonna get some 35's on those slotted mags and back to a 4 inch lift, just $$ is the problem. ![]() picked these 37's on 15x10 steels with 30% tread for 200$! ![]() too much fun! ![]()
#15 |
Re: I need a tranny
Lol im sellin it if you want it
#16 |
Re: I need a tranny
You can only get halfway decent mpg with a lift, big tires and an old truck. If your getting low teens there is no room for improvement imo.
#17 |
Re: I need a tranny
Well i was looking at a rochester carb, as long as i stay OUT of the secondarys (which is very hard since that sound makes me smile downstairs), it actually gets pretty good milage in town lol, the primarys are really small!
#18 |
Re: I need a tranny
Well i picked up a low k nv3500 for 300, I really want to take the housing off and clean the inside, i see some dirt has gotten in. Anyone have a diagram / reference they wouldent mind sharing? i really dont want to screw around with this too much!
#19 |
Re: I need a tranny
Try these folks. You have to drill into the site, but they provide good diagrams and rebuild kits.
http://www.motivegear.com/ Last edited by dan76; 01-14-2010 at 11:55 AM. Reason: clarity |
#20 | |
Still plays with trucks
Re: I need a tranny
That NV3500 won't last long with a big block and 37" tires in something that gets used off road. I broke one in a friends Jeep with 33" tires and a six cylinder this summer doing just one power shift.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#21 |
Re: I need a tranny
I barley ever wheel the truck right now, putting my old 33's back on soon, how long do you think this would last? Any way I can build this tranny stronger?
#22 |
Chevys Kick A$$
Re: I need a tranny
I would check your gearing out that just don't add up man. Those nv3500s don't hold up to much abuse my buddy was running a pretty stock SB and 33"s he broke his like the 3rd time he took it out just messing around nothing to hardcore. Let alone you want to turn 35"s and a BB in front.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
![]() Last edited by Hoods69BadBowTie; 01-14-2010 at 09:31 PM. |
#23 |
Re: I need a tranny
You have to have 5.13s. I don't even thinbk that could have come in a 1/2 ton.... It just doesnt add up.
#24 | |
Re: I need a tranny
With his 37" tires he would be at just over 2300 rpm at the same speed. He either has gears I don't think they make for the 12-bolt (something about 6.20 gears) or he has 3.08 gears and the transfer case is in four low. Nothing else adds up.
#25 |
Re: I need a tranny
I'm glad I have 3.42s!
