Old 01-11-2010, 10:04 PM   #1
gmc1971harwich
gmc1971harwich's Avatar
B&M Unimatic shifter going to give it a try done with column shift!
Ok, so ive gotten completey frustrated with the crappy operation of my column shifter on my truck its non tilt. im going to buy a B&M unimatic shifter, has anyone had experience with this shifter? im on a mega low budget. Anybody know if i can utilize the shift linkage on the column as shift indicator as the unimatic has no shift indicator? maybe tie it in to the cable operation? just wondering if anyones tried this yet. planning on doing this when i get my taxes back so itl be a while trying to plan it out first before trying it.
gmc1971harwich is offline   Reply With Quote
Old 01-11-2010, 10:07 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: B&M Unimatic shifter going to give it a try done with column shift!
im interested on how you do this..may go auto (not sure yet like a man. also..anything but 3ott)
John
1999 Toyota Tacoma 4x4
Old 01-11-2010, 10:26 PM   #3
turp mcspray
turp mcspray's Avatar
I bought one back in the mid 80's. If it's the one I'm thinking of (a bare bones shifter that looks like a 4 speed) They used to be mechanical linkage back then. It worked but I would HIGHLY recommend saving up a little more money, and at least get a Z-gate. It would be a much better shifter.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 01-12-2010, 12:00 AM   #4
Hart_Rod
Hart_Rod's Avatar
Why not try a Lokar or Kugel shift arm kit? They are only about $60 from summit or jegs and they work great.
Hart_Rod is offline   Reply With Quote
Old 01-12-2010, 01:12 AM   #5
RanchFlyer
I used a unimatic in the early 90's. Never was happy. I would suggest steering clear. Just my opinion.
RanchFlyer is offline   Reply With Quote
Old 01-12-2010, 03:35 PM   #6
turp mcspray
Have you looked for a used shifter? I have a hard time believing that you wouldn't be able to any B&M shifter of your choice for $50 or so.
Turp Mcspray
Old 01-12-2010, 03:47 PM   #7
Custom 68
Custom 68's Avatar
I think I am going to swap to a manual tranny but otherwise I would look like suggested at these arm kits. I think you get alot of adjustability and should take care of the problems
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 01-12-2010, 07:01 PM   #8
stevewhitmore
stevewhitmore's Avatar
I have the same problem with my 69 column shifter being real sloppy and shifts without pulling back on the shifter, if you bump it , it shifts out of park.
Would the lokar or Kugal shift arm kits resolve those problems with the same column shifter?
stevewhitmore is offline   Reply With Quote
Old 01-12-2010, 07:11 PM   #9
cparman
sharp as a marble
If that is a ratchet style shifter, I have the perfect place for it. In the trash. I hate those things. I have installed a couple of the Lokar floor shifters, and they seem to work nice, and kind of look like a 4 speed granny gear shifter. I would not do a lokar in my trucks. Column shift all the way!
cparman is offline   Reply With Quote
Old 01-13-2010, 02:44 PM   #10
drewdude92
72 chevys 4 life
drewdude92's Avatar
i have a b&m unimatic that i installed a few weeks ago it works great and was easy to install
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
Old 01-13-2010, 07:17 PM   #11
gmc1971harwich
drewdude did u figure out how to incorporate a shift indicator into it?
Old 01-13-2010, 10:01 PM   #12
QKENUF4U
QKENUF4U's Avatar
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
QKENUF4U is offline   Reply With Quote
Old 01-14-2010, 11:14 PM   #13
gmc1971harwich
does this shifter have a backup switch and neutral safety switch? cant find on website if it does or doesnt
Old 01-18-2010, 09:07 PM   #14
drewdude92
72 chevys 4 life
drewdude92's Avatar
it comes with a sticker thing lol and it has a safety nuetral switch but not a reverse light thingy
Old 01-18-2010, 10:28 PM   #15
chevy72pu
chevy72pu's Avatar
I installed one of these last summer. Mine is cable operated. Install was less than one day. Looks GREAT! Works ok. Maybe I could fine tune it, but it will shift into reverse or park w/o having to press down on the shifter like it says. I have Dakota Digital guages including shift indicator so no linkage was necessary. If I had it to do over again I would probably spring for a little more sophisticated unit.
How 'Bout them Dawgs!
'10 Traverse LTZ
03 Silverado Z71 ext cab
99 Yamaha Grizzly 600
72 C10 350/350 sportside bed.
68 C30 flatbed. 350 4-speed.
"I've got a good memory, it's just short!"
chevy72pu is offline   Reply With Quote
Old 01-18-2010, 10:56 PM   #16
68C15
blood type; Retumbo
68C15's Avatar
what's wrong with the column? I would think fixing it to be cheaper and more reliable.
68C15 is offline   Reply With Quote
Old 01-18-2010, 11:20 PM   #17
gmc1971harwich
havent bought anything yet, im leaning now towards keeping the column shift but updating the linkage witha lokar unit.
Old 01-19-2010, 08:14 AM   #18
stevewhitmore
Let me know how it goes with the lokar shift linkage, I am thinking about the same thing to possibly eliminate the sloppiness in my column shifter
Old 06-12-2010, 09:46 PM   #19
gmc1971harwich
update i bought the lokar linkage and havent installed it yet. been busy with work and a new baby. getting very frustrated with the other stuff associated with column shift like the 3rd neutral safety switch shorting out, and trying to find the right lens for the 700r4. Ive come to the decision of getting rid of the column shift stuff and getting a hurst promatic. already has all the new components including cable. no linkage to mess with.
Old 06-12-2010, 10:37 PM   #20
BHyatt
My truck had one when I bought it. One of the first things i did was find the parts to go back to the column.
BHyatt is offline   Reply With Quote
