Old 01-11-2010, 11:28 PM   #1
ricekiller65
anyone swap 4wd 5 speed in your truck
looking to put a 4 WHEEL DRIVE 5 speed i place of my four speed.. i tried the search and it gave me some awsome results..
that was a joke.. what trans and transfercase??? any help would be apprieciated..
ricekiller65 is offline   Reply With Quote
Old 01-11-2010, 11:31 PM   #2
ricekiller65
Re: anyone swap 4wd 5 speed in your truck
sorry its a 71 gmc short box
Old 01-11-2010, 11:38 PM   #3
MacSic66
Active Member
MacSic66's Avatar
do u have a sm465/np205 or 203? or 208?? ud most likely want to fun a nv4500 (80's pickup).. try advanced adapters for an adapter, depending on the transfercase it might require a new output shaft in the trans.. it can get costly..
another route, depending on which side ur front diff is on(pass or driver) find a mated nv4500/transfercase out of a newer pickup that drops the transfercase on the correct side, if not might have to swap front axles to accomidate ur newer transfercase..
as far a a direct bolt in i dont know of any.. and when u change from a sm465 u loose the granny gear..
No vehicle is "too nice" or "too straight" to cut up.
MacSic66 is offline   Reply With Quote
Old 01-11-2010, 11:44 PM   #4
ricekiller65
ok yeah .. im not needing granny
nv4500 is there one that drops to pass side. i was told all where drivers..
Old 01-11-2010, 11:49 PM   #5
MacSic66
Active Member
MacSic66's Avatar
chevy and dodge are pass drop, ford is drivers drop, i dont know if the nv4500 was used in the fords or not.. it would probably have a np231 t-case, and i think they made those drop either side, weather a ford drop t-case will bolt up to a chevy nv4500 i dont know..
i know the 205 u have they made drop to either side and divorced mout too...
adapters usually run 400.00, output shaft i dunno, then to have it installed u have to have the tranny prettymuch rebuilt...
would you go with an auto overdrive?
Old 01-11-2010, 11:55 PM   #6
ricekiller65
ok thankyou.. my problem is i broke the 205 and was waying my options of different roads. not really wanting the 4 speed at all ..
Old 01-12-2010, 12:00 AM   #7
MacSic66
Active Member
MacSic66's Avatar
cool.. lol, u need parts for it? i have one dissasembeled that came from behind a 465..
ur best bet is get one with the adapter allready there, there are a few different inputs for the 205.. 465, th350, th400, all with different adapters.. i have a np205-th350 adapter, ud need the correct input for the np205, i paid 150 for the new input in my other np205, the th400/np205 is the strongest, most expensive to find or setup from scratch tho..
