01-12-2010, 12:22 AM | #1 |
New front end for a 62
I'm looking for advice on the best way to convert the front suspension on my 62 from torsion bars to coils. Best meaning simplest, best handling, a bolt on application but not necessarily the cheapest.
01-12-2010, 01:26 AM | #2 |
Re: New front end for a 62
You can do what I just did and pull a front cross member off a '72 or equivalent year c-10 and bolt it up to your frame. Its not a direct bolt in by any means but its not hard to do and you get coil springs and 5 lug.
everything I used off a '72 are: front crossmember, upper and lower control arms, spindles, brakes, inner and outer tierod ends. I was able to use the '62 front motor mount for the straight 6, manual steering box with pitman arm, center link (relay rod) and idler arm. You have to redrill a couple holes in the frame to bolt the crossmember up but I think you use one or two original holes so you can use them as a reference.
1984 C10 swb 1985 K20 longbed 4spd 1977 K10 longbed -SOLD 1962 Chevrolet C10 swb 6cyl. 3spd. -SOLD |
01-12-2010, 01:43 AM | #3 |
60-66 Nut
You need a complete front suspension from a '71-'87 C10 pickup, C10 Suburban, or 2wd Blazer
01-12-2010, 02:38 AM | #4 |
Senior Enthusiast
Here's a thread that details how to do it with stock parts:
http://67-72chevytrucks.com/vboard/s...d.php?t=366850 And here's another thread on engine and transmission mounting: http://67-72chevytrucks.com/vboard/s...d.php?t=369663 Last edited by markeb01; 01-12-2010 at 02:39 AM. |
01-12-2010, 10:50 PM | #5 |
Thanks! You guys are awesome.
