Pics of drops and wheel set ups Please
cant decide what drop to install on my 67 c10 with 20" upfront and 22" on the rear can any one provide me with pic's of there truck and can you state what drop is installed on your truck. Thanks i would really appreciate all the help. 67- 72 pics primarily but all are welcome.
Re: Pics of drops and wheel set ups Please
well what you think how much should i lower this truck i want 22 in the back and 20 upfront.
I did my truck on the cheap until i bag it all the info you need at the link
http://67-72chevytrucks.com/vboard/s...d.php?t=361168 |
![]() Join Date: Apr 2009
i have a 3/5 drop and 22's all the way around. would like the rear to be a little lower or just have bags some day...
1967 C-10 Project 2008 Suburban 2017 GMC Sierra |
Tot Roddin'
SBC... why not add a 6" spring or a block?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Wheels are pretty much knock offs i found on CL. i just did the disc brake conversion and 5x5 axle in the rear so i had to find some rims quick to keep driving. they have a Panther center cap so i guess they're supposed to look like them. tires came with the rims and are 265/35/22.
Like i said above, i did everything at once so once i put it all back together i just decided to stick with the 5" drop in the rear. i might try 6" soon or keep the excuse that "its not low enough" so i have to get bags. haha TOMATRZ, i dont mean to jack your post but i think the additional info will help you. i think you need to lower that truck quite a bit so the wheels/tires fill the wheel well.
CopyWritten
I have 20'' up front 22'' out back... Bagged
I have 2 1/2" Drop Spindles in Front along with a 3" Drop Spring.
In back I went with a 4" Drop Spring and a 2" Drop Block for a Total of 5.5 in Front and 6" in back. Currently running 15" B.F. Goodrich Tires.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" Last edited by wwotr; 01-18-2010 at 03:21 AM. |
not a problem man i actually like your set up but i am thinking of going with a bit more meatier tire so i might go with a 2/5
#11 | |
![]() By speed38374 at 2010-01-12 |
#12 | |
I bought everything (to get it to where it is today) at CPP.... (Clasic Performance Parts). It was a Kit that contained the Frpnt/Rear Springs and (4) Custom Nitrogen Filled Shocks. The Shocks were shorter in Length, to make up for the Shorter Travel with a lowered ride. I also bought the 2" Drop Blocks from CPP, and that was the last "puzzle piece" that got the Rear, down to where I wanted it. Theres many more pictures at my website. Just click on the Link below inj my Sig. I THINK the Kit was about $299.99 and the Blocks were around $70.00 I then had my Mechanic install everything. When I originally got the Truck, the previous owner had just Torched and cut the original springs. It was a God Awful/Stiff ride. Once the Spring/shock kit was installed, I didn't hesitate in driving it EVERYWHERE! ![]()
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
#13 |
Project 7dos
5.5/4
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
#14 |
low n' slo
![]() Join Date: Mar 2009
^^^^ nice truck
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#15 |
is that 5.5 up front and 4 in the rear?
#16 |
laying low
![]() Join Date: Mar 2001
That's a solid combo there Roger for sure.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#17 |
Thanks Boog.
Ya know sometimes I get frustrated because things don't hapen "Fast Enough", instead of just enjoying the ride. ![]()
#18 |
My 67 stepside uses 2in drop springs and 2-1/2 in drop spindles in front with 6 in drop springs in the rear to get it sitting level, not that a$$ high pose these trucks usually have. Then I put 8x17's in front and 10x17s in the rear running 235-60 series tires in front and 285-60's in the rear. The total diameter of tires front and rear is 31 inches. That raises the truck back to stock ride height. A quick glance says it's a stocker...you have to look close to see that it isn't. With a 300 pound water bladder in the bed this truck squats and goes....but then it's supposed to!
#19 |
I have a 3 5 drop on my truck with 17" wheels . It is currenly under restoration and I will go 3 6 to level out the back with the front and go with 20's
#20 |
what color red is that last one.
#21 |
I have a 68 stepside that i am wanting to drop. I only have the money to do a spring drop right now. I have heard if you do a 3" front spring drop they can be really hard to align, is this true? Also I heard if you do a 5" rear spring drop you might need to "c" notch the frame, is this true? I was wanting to go a 2/4 but if i can go a 3/5 and not have alignment issues or have to due a "c" notch that would be great. any advise you can give me would be great. Thanks guys. I am running a 235/70/15 in the front and 275/60/15 in the rear just so you know
#22 |
Sofa King Crazy!!
20s in the front and 22s out back.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#23 |
dropmember and bags, stepnotched rear with 20's
#24 |
Tot Roddin'
nastyc10... what are the specs on the wheels/tires? Sick looking truck by the way...
#25 | |
Tot Roddin'
Currently I am running a 6" drop spring and have never bottomed out, and I'm not even running bump stops. If you plan to use your truck as a truck, then you might want to consider helper bags or shrader valves on bags in the rear so you can fill them up to raise the rear as needed. As far as the 3" spring up front... several board members have ran a 3" drop spring without any issues. Now, from what I've heard, when you raise the front end with a jack, the spring has the tendency to come out of the pocket as the suspension raises/lowers. Several board members run a 3" spring without any issues and are able to get it aligned by a reputable shop.
