Old 01-12-2010, 03:50 AM   #1
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Master Cylinder Cover Leaking Brake Fluid How to stop?
I have noticed my inner wheel well wet under my Master Cylinder when I go for a drive then I would wipe it down.My pain is now alittle ruined I thought it was the fittings that were loose so I tightend them but it wasn't, today I found out it was the cover I touched it then it started to make a noise like escaping air from the back of it. So now I know where the fluid is leaking from. Do I just need to buy a new cover or is there a reason why it is leaking through here? This was a new Master Cylinder any help would be greatly appreciated Thanks Pablo.........
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 01-12-2010, 04:05 AM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Master Cylinder Cover Leaking Brake Fluid How to stop?
It could be many things. A) pressure building up inside the reservoir forcing fluid out. B) cracked or missing rubber gasket. C) warped or defective cover D) weak hold down wires E) overfilling reservoirs.(should be no less than 1/4" from top). Actually it could even be a bad casting on the body of the MC. Top edge should be perfectly smooth and flat with no pitting. Hope this helps.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 01-12-2010, 05:35 AM   #3
mikey531
mikey531's Avatar
I had the same problem, I got a new gasket and it still leaked. What I had to do was bend the wire bails to hold the cover on tighter. It hasn't leaked since.
mikey531 is offline   Reply With Quote
Old 01-15-2010, 05:27 AM   #4
petey-pablo
"THE GREEN GOBLIN"
I bent down to tighten the wire hold downs,Hope this solves my problem. It messed up my paint on my wheel well I am just glad it wasn't worse then it is. I think I might have filled it alittle too much but not sure.I haven't driven it much as I just got the truck back from the exhaust shop so I will find out this weekend. Thanks guys
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 03-24-2013, 07:19 PM   #5
1964Chevy
1964Chevy's Avatar
Hey petey-pablo did bending the wire solve the problem
Here is my story. Last April bought MC and booster with proportioning valve from LMC.
Since day 1 the MC cover leaked, I bent the wires and it still leaked.
Pulled it off and bought new MC, tried to install the booster from LMC but it was the wrong one.
Bought a reconditioned booster and installed it, bleeding the brakes with the new MC and booster and it still leaks.........
I'm curious if it worked for you or if it was something else. PS, I also hear it sucking or blowing air out of the top gasket and then see the leak.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline   Reply With Quote
Old 03-24-2013, 08:14 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Some new, after market master cylinders are cheaply made. I had one that leaked like that and wound up getting one at a junkyard in real good shape that worked.
I had another one that did the same and it had a rough surface on the top. I placed it on a vise and laid a flat file across the top at an angle and filed it smooth. Another way is to turn it upside down on sand paper taped to a completely flat surface. If you do this be sure and use brake cleaner to flush and clean the inside out completely.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-24-2013, 08:19 PM   #7
leddzepp
Moderator
leddzepp's Avatar
I had the same problem, and used sandpaper as described above. No more leaks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-25-2013, 08:21 AM   #8
1964Chevy
1964Chevy's Avatar
I'll try to flatten the top. Thanks for the info.
