01-27-2003, 01:48 AM | #1 |
KEEP ON TRUCKING
402 bb ?????
i think our trucks with a bb had a short water pump
will a long pump fit with out any clearence trouble its a non ac i know ill have change brakets/pulleys thanks
72 cheyenne 2wd lwb 71 k20 sons bassett va |
01-27-2003, 02:23 AM | #2 | |
Web Wheeler
Re: 402 bb ?????
Would depend on what you decided to use for mounts. Factory BB mounts do place the engine further forward than with 73-up mounts. (I did a trial fit with both mounts and a spare cracked block.) Might limit room for the distributor though...
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
01-27-2003, 02:34 AM | #3 |
KEEP ON TRUCKING
thanks its a factory bb truck with sb on bb towers gotta 402 to go back in but i dont have the pulleys/brackets yet just wanted to know a buddy has everything for the long pump
01-27-2003, 11:29 AM | #4 |
The long pump puts the fan really close to the radiator and will reduce the effectiveness of the shroud. ALso, accessories swap sides so you will have to extend your alternator wiring harness. Because of the remote reservoir PS pump used on 67-72 trucks, the LP PS pump might not go between the frame rails. And if you have AC it too is flip-flopped so you will have to have longer hoses made.
The more accessories you have on your truck, the more worth your time (or money) it will be to get the appropriate brackets and pulleys.
01-27-2003, 11:36 AM | #5 |
aka Crusher, Crushergmc
My 454 w/long pump fits w/beefed up small block mounts. As long as 1/2 the fan or more is in the shroud, there is no difference in effectiveness. So moving it "back" would be bad (the air will be pulled from outside the shroud if more than 50% is showing outside the shroud.).
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
