Old 01-12-2010, 12:03 PM   #1
ol Curt
Junior Member
ol Curt's Avatar
Use low hump with floor shift?
I'm wondering if I can use a low hump floor/trans cover successfully with a three speed floor shifter?
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 01-12-2010, 12:25 PM   #2
70 Suburban
Rods
Re: Use low hump with floor shift?
I thought i just saw this.. Yes you can.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 01-12-2010, 12:34 PM   #3
ol Curt
Junior Member
ol Curt's Avatar
Sorry to be repetitive, just wanting to make sure there isn't any pounding or cursing involved in the process!
Old 01-12-2010, 12:42 PM   #4
70 Suburban
Rods
just hole cutting
Old 01-12-2010, 09:36 PM   #5
100%Chevy
The question is:
Can you get the hole in the right place?
Mike.
100%Chevy is offline   Reply With Quote
Old 01-12-2010, 10:05 PM   #6
daverod
SSN 706
daverod's Avatar
I have a low hump in mine. No problem man.
daverod is offline   Reply With Quote
Old 01-12-2010, 10:50 PM   #7
ol Curt
Junior Member
ol Curt's Avatar
Originally Posted by 100%Chevy View Post
The question is:
Mike.
mmmmhmmmm Just depends on how BIG you make the hole!
Old 01-12-2010, 10:52 PM   #8
ol Curt
Junior Member
ol Curt's Avatar
Yeah, but yours is an Impala isn't it?
Old 01-12-2010, 10:57 PM   #9
LILRED66
LILRED66's Avatar
Not to sound foolish, but if the hump clears the tranny, then it will work. It is a matter of providing adequate clearance for the shifter, at your discretion. Good luck and let us know what you end up doing.
LILRED66 is offline   Reply With Quote
Old 01-12-2010, 11:04 PM   #10
ol Curt
Junior Member
ol Curt's Avatar
LOL, I just went on your build thread Dave and was marveling at your work...then thought I would look for your shifter and ran across the hatchet man. My wife had to come in and see what I was cracking up about.
Old 01-12-2010, 11:05 PM   #11
ol Curt
Junior Member
ol Curt's Avatar
Well it clears it now...sooooo
Old 01-12-2010, 11:08 PM   #12
ol Curt
Junior Member
ol Curt's Avatar
I found one mounting kit on ebay today and bought it. Wasn't able to find one specific to this truck anywhere else. Tomorrow it will be the shifter. They seem to be readily available.
Old 01-12-2010, 11:33 PM   #13
daverod
SSN 706
daverod's Avatar
My shift kind sucks. Sometimes it gets caught between two gears and won't move. I have to get out and crawl under to fix it. I think it's just worn out. Somthing else I need to update. It has'nt done it for awhile though. Only when I try to shift to fast.
Old 03-08-2010, 12:45 AM   #14
daverod
SSN 706
daverod's Avatar
Did you ever get your shifter installed. Any pictures?
Old 03-08-2010, 10:41 AM   #15
ol Curt
Junior Member
ol Curt's Avatar
It is indeed installed. I should have written it up, but was suffering thru it as I hurt my back in the process and was cussing and suffering thru it. I mad it though. I have some concern about the shift into third. It doesn't feel positive and I fear the shift fork has been bent at some time. However, the doors are off so I haven't driven it.
I am pushing hard after work every day to get everything but the cab ready for paint, but I'll try to take some pictures.
Old 03-08-2010, 12:02 PM   #16
daverod
SSN 706
daverod's Avatar
Do you know what kinda trans you have? I'm thinking I need a new shifter or new shifter parts. Every time I shift fast it get stuck in first. I was looking at the holes they are kinda worn. Maybe my shifter just is'nt meant to be shifted in a reverse N it likes the H. I hate hurting my back, nothing is worse.
Old 03-08-2010, 02:20 PM   #17
ol Curt
Junior Member
ol Curt's Avatar
I broke the output shaft on the 6 bolt sidecover trans in my 66 and replaced it with a 4bolt Chevy 341 trans...non syncro first. I had to have my driveshaft shortened.
I always found binding to be related to the holes being wallered out or needing new grommets and maybe a washer ont he back side to tighten things up..even with my column shift.
Old 03-08-2010, 02:48 PM   #18
daverod
SSN 706
daverod's Avatar
Ya the holes are pretty wallered out. I was thinking of welding them shut and redrilling. I'm going to see if I can maybe get some new parts/grommets. I did'nt even see any grommets. The center shift arm lets go of the reverse/1st arm before its in the neutral postion. Then I'm stuck in first. Wasn't to bad before I lowered my truck so much. Now I have to find a curb to crawl up on to get under the truck. All I have to do is push the 1st/reverse arm into the neutral posn. and it works again. As long as I don't shift to fast and make sure I do a H it all works good.
Old 03-09-2010, 08:40 AM   #19
ol Curt
Junior Member
ol Curt's Avatar
I think the grommets are readily available, but you can usually find some brass bushings that will fit in the HELP brand section of an auto parts store.
Old 03-09-2010, 08:52 AM   #20
lakeroadster
I had a vintage 1965 Hurst "Factory" bayonet style 4 -speed in my 1965 when I bought it. It did all the things you fellas are talking about. Specifically it would hang in second gear.
I tried to adjust it, then installed new rods and bushings. It never was right until I installed a new Hurst Shifter. The shifter mechanism itself was shot. And the price to rebuild the shifter was more than a new shifter?
What a huge difference. Positive shifts and crisp gear selection.
I also grafted in a 2nd generation shifter hump to level things out and cover the gapping hole the previous owners had cut in the floor. The hole was nearly big enough to stick you head thru...
lakeroadster is offline   Reply With Quote
Old 03-10-2010, 09:24 AM   #21
ol Curt
Junior Member
ol Curt's Avatar
My new three speed is a Hurst. It is not sticking but the shift into third doesn't feel positive.
Mine hung when I had the old linkage from my three on the tree.
Old 03-10-2010, 09:55 AM   #22
daverod
SSN 706
daverod's Avatar
I found a 3 speed shifter from Classic parts. Says it's Universal 3 speed floor shifter. Looks just like mine minus the hatchet,$100. I was thinking mine was a hurst. I was having a had time finding one that looked like mine. Guess I'll have to get it coming,
