Shlong Bed Club
i just bought all the stuff to install my bags on my beloved '66 lwb step and was curious to see what everyone else has done with theirs.
Senior Enthusiast
Re: Lets See Some Bag Setups
Here's a few threads with related information:
http://67-72chevytrucks.com/vboard/s...light=air+bags http://67-72chevytrucks.com/vboard/s...light=air+bags http://67-72chevytrucks.com/vboard/s...light=air+bags http://67-72chevytrucks.com/vboard/s...light=air+bags There are also many more threads in the suspension section. |
does anyone know if you have to use the cups on the lower a-arm? I cant bring myself to buy the tubular a-arms and it seems like you could gain a couple of inches by mounting the bag directly to the bottom arm and leaving out the cup........?
SSN 706
I think you can cut some of the cup off.
but how come you have to have it at all? couldnt you just drill the mounting holes in the bottom spring pad or even just use a piece of flat plate, just curious if theres something that makes the cup idea necessary?
Shlong Bed Club
I think you're supposed to use the cups so that the bag doesn't rub the a-arm. i think you're "supposed" to use a #3800 bag with our trucks which is like 8.8" in diameter. makes sense to me.
Makes sense, i will have to see how it works out, im coming up on the switching the drop springs for bags part of my build and i have 4 RE7 bags and i have the top plates and bottom cups for the front so i will have to experiment a little bit.
Resistance is Futile
I cut my cups down about 1/2'' to let them set in the a-arm a little lower. It's commonly done on this set-up. Check the measure before you do it....memory from about year and a half ago
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
