Old 01-12-2010, 06:00 PM   #1
capev86
LED bulbs
been thinking about upgrading some of the lighting in my 72 burb with LED's. not looking to go to a high dollar conversion, just use some replacement bulbs. figure i can change the running light bulbs. if i don't change all the directional bulbs i should be able to do without a resistor or whatever you have to wire in to account for the lower current draw and still have the flasher cycle on and off. i also need to change out a dead (left) blinker on the dash when i pull it to add the tach and vac gauges. especially in the dash, LED's should be a nice touch since they won't have to be replaced very often, and draw far less power. i have a stock alternator with external regulator (mechanical unit replaced with slim electronic one). oh....i see in the latest LMC catalog that they carry a clear modern style lens for the stock interior light and also an LED bulb for it.
if anyone has a line on part number for replacement bulbs or the places with the best prices....let the rest of us know....thanks!
capev86 is offline   Reply With Quote
Old 01-12-2010, 09:25 PM   #2
mvfd70
mvfd70's Avatar
Re: LED bulbs
I've used www.v-leds.com before. They seem to have a pretty nice selection.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 01-12-2010, 09:32 PM   #3
theslawdawg
theslawdawg's Avatar
Re: LED bulbs
So what is required (wiring, extra parts wise) if you want to change out to the LED style? Or can you just pop in the LED bulbs?
1972 Chevy C10
theslawdawg is offline   Reply With Quote
Old 01-12-2010, 09:41 PM   #4
energiesource
Re: LED bulbs
i re-did the lighting in my explorer with LED's i just bought 100 led's on ebay for $30 and wired them in, whether it was project board, or made bulbs. here are some pics. it was definitely worth it for me. better lighting and i learned alot.
energiesource is offline   Reply With Quote
Old 01-12-2010, 09:42 PM   #5
energiesource
Re: LED bulbs
whether you hardwire it in, or make a bulb like i did, as long as it has resistors for a 12v application, youre good, just get the positive and negative right, the resistors go on the positive end. most LED's on ebay come with free resistors.
if you want to buy them instead, superbrightleds.com has a good selection. if you want the brightest though go with the SMD ones.
Old 01-12-2010, 09:46 PM   #6
big mike71
big mike71's Avatar
Re: LED bulbs
There's somebody on here that makes them, But I can't rember his name
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 01-13-2010, 02:13 AM   #7
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Re: LED bulbs
http://67-72chevytrucks.com/vboard/s...d.php?t=374289
Beatcoaster is offline   Reply With Quote
Old 01-13-2010, 03:14 AM   #8
70cst
70cst's Avatar
Re: LED bulbs
You are correct big mike71...see LINK below
For sale: Hand-Made Custom LED Brake and turn signal lights.
http://67-72chevytrucks.com/vboard/s...&highlight=led
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
