Old 01-12-2010, 08:50 PM   #1
68_Step
Question Brake drum removal - Dually
I am in the process of giving my 78 Chevy 1-Ton dually a rear brake job. I have it on jacks stands, the tires off and have removed the axle shafts from both sides. I think I have to remove the nut in the axle tube also, is that correct? If yes, how do I remove the "nut"? It is circular with round indentations in it - is it a sort of spanner wrench? I can also see a lock washer with a tab bent over holding it in place, that part looks easy
Thanks for the help!
68_Step is offline   Reply With Quote
Old 01-12-2010, 09:39 PM   #2
arkracing
Weekend Warrior
Re: Brake drum removal - Dually
yeh there is a socket to remove that "spanner" nut. Your local autoparts store should have them - around $15ish
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 01-13-2010, 08:19 AM   #3
68_Step
Thanks Arkracing, you were right - I found one online at O'reillys, part number 2770, by KD.
Is this it? The link goes to O'reillys. I also found this pic on another website:
Old 01-13-2010, 08:39 AM   #4
arkracing
Weekend Warrior
I thought that the rear ends used the 6 pin socket. If your spanner nut only has 4 slots then that should work. If it has 6 then it wont work
-'66 C10 Suburban
Old 01-13-2010, 09:36 AM   #5
68_Step
I think mine has six slots/holes. I just noticed that the pic of their advertisement I posted is goofed up. The text in the advertisement says 6 lug, but the pic is of a 4 lug.
I just ordered KD Tools - Spindle Socket #2770 from my local O'reillys - will have it by lunch time and I can test it tonight.
Old 01-13-2010, 10:25 AM   #6
Adams74Chevy
Adams74Chevy's Avatar
The following isn't the "best" way but it works in a pinch...
a punch or a screwdriver and tap w/ a hammer.
The socket is handy to have.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 01-13-2010, 11:20 PM   #7
68_Step
I ordered and received the spindle socket from our local O'reillys. The one I got did fit correctly and I was able to remove both the nuts and then the rear drum. Of course that means more questions, but I will save them for another thread.
The socket was made by KD Tools, part number 2770. It fits the spindle nut on a 78 Chevy, 1 ton, 4x4, dually. Oh yeah, it has 6 lugs/pins.
Thanks!
Old 01-14-2010, 12:50 AM   #8
loverofchevystrucks
There are two spanners nuts you take off and the drum comes off. I just learned last week when i did my rear brakes. I didn't use a special socket. Just tapped it with a punch. There also might be a retainer ring and a key mine didnt but thats what the repair manuel said. Ou should replace the seals while you have the drums off. If you have any ?s hit me up
loverofchevystrucks is offline   Reply With Quote
