driveshaft on 72
My friend is in need of a drive shaft for his short wheel step 72. He bought it a few months back without one. He then got a long wheel base with engine and trans we removed and put in his stepside this last week. My 72 has a 1 piece drive shaft, but another 72 on his shop he is painting has a 2 piece drive shaft. I am curious what was stock in 72?
Moderator
![]() Join Date: May 2007
Re: driveshaft on 72
2 piece is stock for our trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I have the truck he mentioned. I bought the red assembly manual for the 67-72 trucks. it shows 2pc and 1pc drive shafts. im lost where this comes in. we both have 72 frames that i know of. both swb. mine has mounts for a 2pc shaft system and his doesnt.
so one come with 1 piece in 72? wonder why mine would be modified.
they also have slip yoke, and non slip yoke 2 piece driveshafts
Junior Member
My '71 has a two piece driveshaft because it is a 4 speed. It has to have the slip joint in the middle because the yoke on the 4 speed doesn't slip in and out.
When my son builds trucks with automatics he goes with a one piece. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
![]() Join Date: Feb 2009
I don't have a good picture of my front drive shaft, but I have two bad pictures of my 72 K20's.
-Scott 1972 Chevy K20 Picture Gallery Build Thread 1930 Chevy AD Picture Gallery 1929 Ford Model-A Picture Gallery 1975 Triumph TR-6 Picture Gallery |
iirc, 6 cylinders 2wd short beds came with 1 piece. SBC 2wd short and long beds came with 2 piece drive shafts. Not sure on 2wd 6 cylinder long beds or 4x4's. Chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
4x4's had a single piece rear, due to the length of the tranny + x-fer case.
SWB I6 manual trucks did come with a 1 piece shaft. Probably automatics too. The key to which driveshaft you can find standard is where the engine is mounted and what wheelbase you have.
