Old 01-12-2010, 11:50 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
confused. differentials
I was hoping someone could help me with this.
If I take off from a stop light, real quick like it'll let one tire loose. If I'm stuck in the mud/snow and romp on it, it'll spin both tires, hell it'll spin all 4 and look pretty sweet.
This is all on a 1979 K10, I don't understand why it will spin both tires on say ice but it'll do the one-wheel-peel on the dry stuff.
Can someone explain this to me?
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 01-13-2010, 12:06 AM   #2
onlyifihadachevy
Re: confused. differentials
I'm assuming when in the mud and snow your stuck by the way of high centering. So no tires are touching the ground. And on the dry stuff one tire is planted on the ground, the other is spinning unable to get traction.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 01-13-2010, 01:28 AM   #3
1970GMC468
1970GMC468's Avatar
Open diffs will occasionally spin in the loose stuff if the truck is straight and everything is perfect. If you have a posi traction rear end it is possible that the clutches are worn out and not grabbing well on the dry stuff. Just my two cents.
1970GMC468 is offline   Reply With Quote
Old 01-13-2010, 11:18 AM   #4
Burt4x4
Burt4x4's Avatar
Yup, open diff or worn limitedslip/posi
Take the rear cover off and see what is in there, If you need help identifying it snap a pic and post it up.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-13-2010, 04:16 PM   #5
Benelli
Benelli's Avatar
Will do, thanks guys.
Old 01-24-2010, 02:31 PM   #6
Benelli
Benelli's Avatar
Open?
Old 01-24-2010, 03:19 PM   #7
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
That's Open,single spinner, one wheel peel.
powerdriver 1958 is offline   Reply With Quote
Old 01-24-2010, 04:11 PM   #8
Benelli
Benelli's Avatar
And looks almost recently rebuilt?
Old 01-24-2010, 04:15 PM   #9
powerdriver 1958
Kid's Mechanic
You may be right,the black haze that generally builds up in the spiders is not there.Do you know any history on it ?
Old 01-24-2010, 09:57 PM   #10
Benelli
Benelli's Avatar
I know no history at all on the rear-diff.
New motor a few years before I bought it and the transfercase was rebuilt and it was painted. He didn't mention anything about it. There was a huge shear or scratch looking thing inside the differential that looked like it shoudln't have been there, almost like something broke and flew off?
