Slow Old Timer
![]() Join Date: Apr 2000
How are saddle tanks supposed to be mounted?
I have a pair that originally came with my 72K20 but the PO removed them (not very carefully I might add). Is there a long bolt or rod that goes down through the middle of the tank and then up through the bed floor? Or how should they be mounted is maybe what I should ask?
Re: How are saddle tanks supposed to be mounted?
My saddle tanks made by Travel Tanks was mounted with two long bolts through the tank on each one. Here's a couple pics from when I removed them.
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
Every one I've ever seen is like the ones pictured all the way from Sweden.
Like Mats I had to grind the heads off BOTH of my bolts in the bed to drop the tank. (It looks like Mats only had to grind one off) After I had my tank leak fixed I had to get it mounted again. First I reamed out the holes through the tank to clean out the rust, clay, sand, salt, and what ever else was in there. I then tried to coat the inside of these holes with POR-15. I also coated the outside of the tank with POR-15. Then I had to make new mounting bolts because I destroyed the heads on the old ones and didn't even attempt to unscrew the original fasteners. To do this I bought some 1/2" threaded rod and short 1/2" carriage bolts with the same thread. After a little measuring I cut the threaded rod to the length I needed and welded it to the carriage bolts. Then I just used 1/2" nuts and 1/2" fender washers under the tank to hold it in place. It has been hangning there now a good 10 years.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Slow Old Timer
Those are exactly the same tanks I have. I was just a little incredulous about hanging all that weight on two bolts but it obviously has worked well for you. Side topic, did you coat the inside of the tanks or treat them in any way? I've heard of something called Kreem or something like that is supposed to work well. Also, it does not appear as though these tanks have any type of sending units. Were they plumbed as secondaries to the main tank or how did you know when they were getting low (other than obvious)?
Thanks for the replies! Way cool to see this coming from Sweden, our trucks truly have global appeal! |
#5 | |
I have a Blazer tank I've been meaning to install. It too now has been sitting probably too long. I figured I'd get the eastwoods kit and give that a try - if I ever get around to installing it.
#6 | ||
The original and the two saddle tanks were plumbed together with a 3-way selector located on the floor on the left side of the seat. The attached pic shows some details, lower part of the bolt, the 3-way selector and the sending unit. Glad if this could be of any help and I assures you these trucks have global appeal ![]()
Never Ending Projects
My first '68 had the setup like the picture above. Two tank, sending units, a selector valve and I had a toggle switch to select the sender. Two bolts thru the floor and one little tab to the lower lip of the bedside, near the wheelwell.
My current one used a completely different mounting setup. It was a flat bar that bolted to the frame and a long bolt (like above) for the outer mount. It basically pulls the tank up to the underside of the bed. Tank has no sender either.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#8 | ||
20' Daredevil (Ret)
![]() Join Date: May 2003
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 01-13-2010 at 06:46 PM. |
#9 | |
While I had my tank out I purchased a sending unit and fuel gauge from JC Whitney. Since I'm a chicken and was afraid of blowing myself up I filled the tank to the top with water then used a hole saw to cut a hole the size spec'ed in the gauge/sender instructions. I mounted the fuel gauge knee-knocker style under the ignition.
