01-13-2010, 01:13 AM | #1 |
WTB Transmission shifter part
I have a 71 3/4 ton 4x4 that I'm going to convert from manuel to auto. I think I have all the parts to do it except the bracket that physically bolts to the tranny. I don't know what it's called but it's shaped like a square C and the shifter from the frame bracket hooks to it. It has the little spring, washer and cotter key in it. Thanks Jared
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
01-13-2010, 01:55 AM | #2 |
SWB 4x4 Collector
Re: WTB Transmission shifter part
You might try sending a message to Randy (Teeitup), as he might have the pieces you are after. If you don't mind me asking, what does your manual shifter look like? Is it chrome? Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
01-13-2010, 06:51 AM | #3 |
Here is a picture for reference on the parts that you need.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-13-2010, 03:14 PM | #4 |
I need the Shift lever. My shifter has a T-handle welded to the top of it.
01-13-2010, 08:28 PM | #5 |
Not to rob the post but does anyone repop the bellcrank for 4X4's?
69 stepside, 1/2ton, 4X4, 350/350/205 |
01-14-2010, 03:00 AM | #6 |
Moderator
Jared- I believe this is what you are after. It is all original...complete with the spring, both washers, and cotter key. PM me your address and it is yours.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-14-2010, 10:26 AM | #7 |
Under Construction
KIND Gesture!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
01-14-2010, 09:30 PM | #8 |
If it fits a 4x4 I'll take it.
Does anyone know if these are different or the same between 2wd and 4x4?
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made Last edited by sweet70beast; 01-14-2010 at 09:36 PM. |
01-15-2010, 03:30 AM | #9 |
Moderator
On that particular part, there is no difference. The difference is in the pivot bracket on the frame, and the shifter rod itself. If I am wrong, someone please correct me on this.
