Old 01-13-2010, 04:05 AM   #1
C.W
Z bar/bell crank question
What years of truck can i get a Z bar/bell crank from for my 71 chev 350, 4spd?
I cant compare to mine as someone stole the one off my truck while it was stored at a friends.
86 Burb, 5/7 drop, 18" rims, big stereo, work in progress, as well as daily driver.
86 Short box just starting the build.
86 GMC 1500 2wd, ugly blue farm looking truck with a mild 454... More to come!
98 Cheyenne Ext cab short box 2wd. Driver and maybe future project.
C.W is offline   Reply With Quote
Old 01-13-2010, 04:58 AM   #2
Smallz72project
Smallz72project's Avatar
Re: Z bar question
Im sorry for the possibly ignorant question, but what is a Z bar and where on the truck is it located?? I have never heard of such a thing other then in reference to say like motor cycle handle bars that are in the shape of Z's.
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 01-13-2010, 05:06 AM   #3
C.W
Re: Z bar question
Its part of the clutch linkage that goes from the ball stud on the engine block to the frame. Connects the clutch pedal to the rod goint to the clutch fork. Hopefully that makes sense, its been a long day.
Old 01-13-2010, 05:35 AM   #4
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: Z bar question
its actually called a bell crank.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 01-13-2010, 05:49 AM   #5
C.W
Re: Z bar question
That was the other name i was looking for. Thank you.
Like i said, been a long day.
Old 01-13-2010, 06:28 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Z bar question
"Z-Bar" is accepted Chevy slang for the clutch bell crank.
Back to the original question-- I think the '67-'72 V8 4x4 Z-Bar is fairly common.
Old 01-13-2010, 06:30 AM   #7
JimKshortstep4x4
Re: Z bar question
The 67-72 V-8 trucks, (2wd or 4wd) Z-bars will fit. The 6 cylinder Z bars are too long.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-13-2010, 06:30 AM   #8
C.W
Re: Z bar question
73+ will not work at all then?
Also i have read conflicting answers about the ball stud on the block. Does it thread directly into the block or into a bracket?
Old 01-13-2010, 08:09 AM   #9
rsavage
rsavage's Avatar
Re: Z bar question
Threads into the block. Don't know if a 73 and up z bar would work.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-13-2010, 02:49 PM   #10
gerfunken
gerfunken's Avatar
Re: Z bar question
I don't believe that they will work. I know that Grumpy's Truck Parts here in Phoenix, AZ carries them..... After breaking the weld on one of mine, I was frantic at the time to find a replacement. Granted, that was before I joined this wonderful board.
http://www.grumpystruckparts.com/productCat60300.ctlg
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 01-13-2010, 03:27 PM   #11
Smallz72project
Re: Z bar question
Ah, that makes sense. Learn something new everyday. I just took mine off my 67 yesterday. Not planning on keeping the manual. I can take a picture of it and if it works for you its all yours for just the shipping.
Old 01-13-2010, 03:59 PM   #12
C.W
Re: Z bar question
Was yours a small block v8 truck?
Are you able to see what shipping would be to Penticton BC Canada, Postal code V2A-2J6?
Old 01-13-2010, 05:10 PM   #13
pumpkin
pumpkin's Avatar
Re: Z bar question
Got one.
pumpkin is offline   Reply With Quote
Old 01-13-2010, 05:12 PM   #14
C.W
Re: Z bar question
Originally Posted by pumpkin View Post
Got one.
How much?
From a small block 4spd truck?
Will you throw it on the bus?
Old 01-13-2010, 11:35 PM   #15
Smallz72project
Re: Z bar question
Yes it is off of a 327, have the bracket that the ball stud screws into as well. But let me know cause Im sure it would be way easier and cheaper for you to get the one from Pumpkin if its the right one. The one I have needs to be refurbished also, the bushings/dust shims are pretty haggered.
Old 01-13-2010, 11:49 PM   #16
C.W
Re: Z bar question
Is that bracket with the ball stud for the block or frame side?
Old 01-14-2010, 12:00 AM   #17
MAK191
Re: Z bar question
If I remember correctly the ball stud in the picture is mounted to the block and the z bar in the picture has a nut on the other end (with another ball) that mounts to the frame, just like the 1st picture. 2nd picture the z bar is flipped around. Your frame should have the other bracket riveted on from the factory.
MAK191 is offline   Reply With Quote
Old 01-14-2010, 12:12 AM   #18
C.W
Re: Z bar question
Is the bracket needed on the block or is it just for blocks that dont have the threaded hole?
Mine is just threaded into the block itself. But im not sure if its the original engine or not.
Old 01-14-2010, 01:26 AM   #19
Smallz72project
Re: Z bar question
The bracket with the ball stud bolts onto the block and the other end has a ball stud that just has a nut and it sits inside a bracket that is riveted to the frame as Mak191 said. Although I can also send the frame bracket as well. But again just let me know because Im sure that it would be more cost and time friendly to get one that was already in canada.
Old 01-14-2010, 03:08 AM   #20
'68OrangeSunshine
Re: Z bar question
My '71 GMC Jimmy has just the ball stud that goes right into the block. No engine side bracket. Is that a K/5 thing?
'73 -and-later clutch linkages are way different from '67-'72 series stuff.
Old 01-14-2010, 12:56 PM   #21
69 longhorn
Re: Z bar question
2wd uses the bracket on the engine, but I beleive that the 4wd uses a screw in ball in the block(due to engine placement). crazy AL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 01-14-2010, 05:21 PM   #22
C.W
Re: Z bar question
My 2wd only has the screw in ball stud. It may not be original, but how for off would the alignment of the bell crank be that way?
Old 01-14-2010, 05:28 PM   #23
C.W
Re: Z bar question
PM sent.
Old 01-14-2010, 07:24 PM   #24
69 longhorn
Re: Z bar question
If your truck was originally an I6, it most likely has a sb mounted on the original 6cyl frame stands.....that moves the eng back 3 1/2" from factory sb V8, or same as 4wd spot. In that case i have found a screw in ball to work out well. can you post a pic of the eng compartment? crazyAl
Old 01-14-2010, 09:15 PM   #25
C.W
Re: Z bar question
Actually i went back out and checked it a little closer and wiped the oil and grime off a bit and it appears it does have the bracket with the ball. So i was mistaken before i guess.
