Old 01-13-2010, 06:11 AM   #1
MobSled
MobSled's Avatar
Speedo?
Here's the deal guys...this past Saturday I decided to lower my truck, 5/6 drop. I was running a 255/70/15 tire all the way around which we all know is too tall for a lowering job like that. Decided to run 245/60 and 275/60/15 in the rear. Now for some reason I lost my mph. My speedo shows 70 when in reality I'm doing 55-60.
Any inpuit would be greatly appreciate...btw its a 1977 c10 LWB.
My 2 questions are what caused this, how do I get my top speed back?
MobSled is offline   Reply With Quote
Old 01-13-2010, 11:23 AM   #2
MobSled
MobSled's Avatar
Re: Speedo?
Not sure if this help guys but I can safely rule out the cable because while my mph gauge is showing 70mph my rpm gauge is at 2300 2400rpm. In reality I'm only doing about 60mph. I will get a more accurate reading on my way back home using my gps which is 99% accurate in all my other cars untill then let me know what you guys are thinking, if anything comes to mind.
THX.
Old 01-13-2010, 11:26 AM   #3
MobSled
MobSled's Avatar
Re: Speedo?
Old 01-13-2010, 03:27 PM   #4
willett
Another Day, Another Dollar
willett's Avatar
Re: Speedo?
my spedo cable has done some funny things in the past while on a straight stretch of road. it has started to "jump" 0 - 160 and then to 100 and then all the way around and then back down.... etc.
i would yank you spedo cable and make sure that there are no crazy bends, as well as lube er' up with a touch of graphite.
bigger tires in the rear would suggest that the spedo should be reading lower speeds if anything....
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-13-2010, 03:34 PM   #5
MobSled
MobSled's Avatar
Re: Speedo?
Well that's just the thing I went from a 255/70/15 tire in the back to a 255/60/15...I guess I could be missreading my rpm gauge. On a 350/350 combo with a stock 77 rear diff, while cruising down the highway at 65mph where should my rpm be?
Old 01-13-2010, 03:46 PM   #6
TwoFiftyShifter
Re: Speedo?
Depends on the axle ratio. If its a 373 it might be 2800 rpm or so.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 01-13-2010, 03:52 PM   #7
MobSled
MobSled's Avatar
Re: Speedo?
So 70mph 2300rpm doesn't sound right at all?? Sorry for all the noob questions fellas I got into the muscle scene about 3months ago. Another question is what's a healthy rpm I can take a bone stock 350 up to?
Old 01-13-2010, 04:00 PM   #8
TwoFiftyShifter
Re: Speedo?
No it really depends on your axle ratio, what I said is close for 3.73, but if you have a 3.07 ratio that would be correct.
1982 K10 SWB
Old 01-13-2010, 04:01 PM   #9
TwoFiftyShifter
Re: Speedo?
4500 RPM is pretty safe max rpm.
1982 K10 SWB
Old 01-13-2010, 04:37 PM   #10
3r!c84
Badass
3r!c84's Avatar
Re: Speedo?
you went down in tire diameter so it will throw off your speedo.just like changing your rearend gears
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-13-2010, 05:03 PM   #11
MobSled
MobSled's Avatar
Re: Speedo?
So how do I go about recalibrating my speedometer cable its showing 9mph faster then what I'm actually driving.
Old 01-13-2010, 05:06 PM   #12
3r!c84
Badass
3r!c84's Avatar
Re: Speedo?
get a diffrent size speedo gear.its on the tranny on the drivers side.at the tail of the tranny.you insreww that and a gear comes out.you can go to gm or a parts store might have them and get a size smaller or bigger(i dont know what way to go)but ask them they will know
-00 Saturn 5spd
1/4:13:90
