Old 01-13-2010, 10:34 AM   #1
TwoFiftyShifter
SPID Question
The SPID located on the glove box door of my truck has a bunch of 3 digit codes on it.... but all the ones I see on this site list the options??? How to a decode this thing?
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 01-13-2010, 11:15 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: SPID Question
Can you post a pic?
I will confess that some of the SPID labels I see have additional characters and I don't know what they are for. They may not mean anything...
For example, mine has "9" before each entry:
9CD4 - Pulse Wipe
9E63 - Fleetside box
9GT4 - 3.73 rear axle
9G80 - Locking rear axle
etc. I recognize the three digit RPO code but not the "9". I have seen others that have an extra single digit and even multiple digits but, as I say, if you are somewhat familiar with the RPO codes then the extras may not be significant.
- OR - are you saying it has the codes but not the noun names, so you don't know what the codes mean?
Post a pic if you can.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-13-2010, 11:34 AM   #3
TwoFiftyShifter
Re: SPID Question
Kinda tore up, but the only one I can identify is the G80 locker.
1982 K10 SWB
Old 01-13-2010, 11:40 AM   #4
Keith Seymore
Re: SPID Question
Oh, ok -
I think there is an RPO decoder on site here (or on one of the linked sites) but I know a bunch of those off the top of my head:
A01 - Tinted windshield
A52 - Frt bench seat
B84 - body side molding
B96 - wheel opening moldings
C6P - 8600 lb GVW
D45 - Mirror stainless steel (buckeye type)
...can't read...
G51 - Heavy Duty springs rear
JAN - Janesville assy plant
MM4 - processing option, manual trans
M20 - 3 speed manual with granny low
NA4, NA5 - emissions packages
V01 - Heavy Duty radiator
V22 - uplevel grille
ZY1 - single color paint
Z53 - gages
I think that's the high points. Is there a specific one that I can't read that you are interested in?
K
1979-1986
1986 - 2019
Old 01-13-2010, 11:46 AM   #5
Keith Seymore
Re: SPID Question
9CD4 - Pulse Wipe
So I guess all this was pretty much worthless, eh?
1979-1986
1986 - 2019
Old 01-13-2010, 11:57 AM   #6
TwoFiftyShifter
Re: SPID Question
Yeah, pretty much all of my codes are different. I found the decoder, but haven't read any cool codes yet... like the axle ratio.
1982 K10 SWB
Old 01-13-2010, 11:59 AM   #7
Keith Seymore
Re: SPID Question
I can't read it in your photo: what code are you showing for the axle ratio? If it's a GU6 then that's a 3.42:1.
Also: model number - CV20903:
C = Chevrolet
V = 4WD
209 = long wheel base 3/4 ton
03 = regular cab pickup
3/4 ton pickup with the M20 trans; sounds like a pretty serious truck! (lol)
The truck in question must be the '87 K20 in your signature....
1979-1986
1986 - 2019
Old 01-13-2010, 12:17 PM   #8
TwoFiftyShifter
Re: SPID Question
Thanks for the info, I did the thing where you marked the driveshaft and counted the turns and got about 3 and a half, I figured it was a 3.73, but by trying to maker out that code it looks like its GU6, so it must be a 3.42. Doesn't rev to the moon like a 4.10 truck does so that may be right.
1982 K10 SWB
Old 01-13-2010, 12:20 PM   #9
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: SPID Question
I think this is what you need.
http://73-87.com/chevy_ids/rpomenu2.htm
Slonaker
EDIT: When I saw this I thought you were talking about South Padre Island Drive in Corpus Christi, Texas.
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-13-2010, 12:25 PM   #10
Keith Seymore
Re: SPID Question
Yes - GT4 = 3.73; GU6 = 3.42, so it should be pretty easy to tell them apart even on a damaged label.
Slonaker - thanks for the link. I'm still compiling "my favorites"...
K
1979-1986
1986 - 2019
