3/4 ton leafs to 1/2 ton leafs
Im interested in switching out my 3/4 leafs out for 1/2 tons. Are they the same length? I'd like to lower it some. Or should i just take out some springs from what i have.
Oh and on a side note can you swap front springs out to half ton? Last edited by msgross; 01-13-2010 at 10:07 PM. Reason: corrected for owner |
Re: 1/2 ton to 3/4 ton leafs
half ton are usually coils in the rear.
front coils are interchangeable |
what are you trying to achieve, softer ride?
You could remove a leaf and replace it with a zero rate from ORD.com
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
I know there are like 1000 threads close to this but the search isn't working. I know most are coils but I'm talking about the leaf spring ones. I think gmc came standard with leaf and coil was optional? Chevy was the opposite.
Oops the title is backwards. |
Re: 3/4 ton leafs to 1/2 ton leafs
updated main title for you...
I worked at a spring shop for a few years and as far as oem springs they were the same on the front weather 1/2 or 3/4 sometimes on the 3/4 we would add an extra making them a 3 leaf spring pack. Thats if its a 4x4. When we would add new springs in the front we would put them in as a pair due to the fact that it would actually lift the front about 2 inches compared to the original wore out springs
Sorry I should have said it from the beginning but my truck is two wheel drive.
