01-13-2010, 08:17 PM | #1 |
thermostatic switch (to control electric fans) question???
I'm in the process of converting my truck to electric fans. I'm using the Altima fans from this FAQ http://67-72chevytrucks.com/vboard/s...ad.php?t=50085
I also bought a fan control kit from Summit http://www.summitracing.com/parts/HDA-3652/ I mounted the fans directly to the radiator and everything went good, I wired them up and tested them and I could activate the fans manually but I think the thermostatic probe/switch that goes into the radiator is not working, I checked the temperature right next to it using a food thermometer and it was 200*, but the switch will never turn on. it's getting power to it, but its just not working. I doubt I can send the kit back, I bought it a couple of months before I bought the fans. Is there anywhere I can get one locally (radiator probe or coolant sensor)???? are there any oem applications for this kind of switch????
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
01-13-2010, 08:30 PM | #2 |
Junior Member
Re: thermostatic switch (to control electric fans) question???
O'Reilly's Auto Parts has a controller that goes into the radiator, I am sure others do also.
I am not sure of the price. What is the temperature supposed to be at when it turns the fans on? Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
01-13-2010, 08:33 PM | #3 | |
I looked at Oreilly's today and I didn't see one. is it vehicle specific????
01-13-2010, 08:41 PM | #4 |
I spent the extra for a varable controlled sensor. (160-200) The difference in price was only 6 or 8 bucks more.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
01-13-2010, 08:43 PM | #5 |
Any decent rad shop should have them in stock.
01-13-2010, 08:58 PM | #6 |
I use the DERALE 16759 kit for my S-10. Been on for almost a year n a half.
I also just ordered it again literally last night to use with the Jeep fan I ordered for the 67. It is adjustable, has an A/C override switch, which I need, and radiator probe. I got it on fleabay for $38. I had no problem wiring it in my S-10. http://www.derale.com/
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-13-2010 at 09:00 PM. |
01-13-2010, 09:43 PM | #7 |
Hollister Road Co.
How are you manually starting the fan? If you ground the dark wire on the probe it should come on. The light colored wire is a grounds and it should be grounded where the fan is gronded.
If you ground the dark wire and it comes on then you have it correct to the sensor. If you cross the sensor terminals and it comes on then its the probe. If you cross the terminals on the probe and it does not come on then you have to check that the light wire is grounded. Last edited by dwcsr; 01-13-2010 at 09:43 PM. |
01-14-2010, 11:29 AM | #8 | |
01-14-2010, 12:23 PM | #9 |
Never Ending Projects
This is the one I am going with, the Spal unit. Fully adjustable, uses any electric gauge temp sensor (or it's own) and ramps up the fan speed as the temps rise. Will do dual fans, variable on one fan, when temp reaches max you set, it will kick on the second fan.
Read more at http://www.spalusa.com/store/Main.as...tem=FAN-PWM-V3 Good price for it here, http://www.speedwaymotors.com/Spal-P...ign=GoogleBase
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-14-2010, 01:39 PM | #10 |
Oreillys keeps them behind the counter if you can find a parts guy that has half a clue.
Heres the part number: Hayden - Thermostatic Fan Control Part Number: 3647 |
01-14-2010, 10:33 PM | #11 | |
Hollister Road Co.
01-15-2010, 07:40 PM | #12 | |
01-15-2010, 09:19 PM | #13 |
Pricey, but sounds like a nice setup.
01-16-2010, 02:18 AM | #14 |
Hollister Road Co.
They are nice but have limits on how big a fan you can safely power. Don't try to run a Mark VIII off it. If a DC control is what you want the go over to http://www.dccontrol.com/
