01-13-2010, 08:19 PM | #1 |
Front drum bearing help needed
I got a little up and down movement in my front hub on one side, so I am going to do new bearings, my question is how does the inner bearing come out? It doesn’t look like it had a seal and the bearing is wobbling around inside, isn't the bearing cup supposed to hold it tight?
Second question, my truck is a 67 with front drums, does anyone know what part numbers I need, NAPA is saying bearings for an IFS 25 axle? I don’t want to do the back and forth to the parts store if I can help it. Thanks for any info on this.
Mark 1967 C/10 stepside lwb daily driver 1968 C/10 fleetside lwb parts truck 1971 Cheyenne Super swb project |
01-13-2010, 09:35 PM | #2 |
Re: Front drum bearing help needed
The bearing cup should be a press fit in the drum. You may want to replace the drum as a new cup will fit loosely in it.
I don't understand what NAPA is coming up with. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-13-2010, 09:56 PM | #3 |
If it is 2 wheel drive the inner number for timken is set5 if its 4 wheel drive the timken is a set37
67 GMC SW 383 stroker/TH350 w/ 4.56 gears - under construction 04 GMC 1/2ton daily 07 GMC Acadia wifes daily |
01-14-2010, 08:35 AM | #4 |
So is the outer set2?
01-14-2010, 09:27 AM | #5 |
a replacement drum has no hub
01-14-2010, 09:35 AM | #6 |
Between Trucks...
On my C-20 the hub and drum are separate, and the inner bearing is held in by a seal in the hub. I assume it's similar on a C-10.
Beat it to fit, Paint it to match... Last edited by Sinister; 01-14-2010 at 09:49 AM. |
01-14-2010, 12:26 PM | #7 | |
One other question, how do you remove and install the bearing cups, are they a press in thing, I assume this will have to be done in a shop?
01-14-2010, 01:00 PM | #8 |
Between Trucks...
The bearing cups have to be pressed out of the hub, and new ones pressed in. Not sure if this could be done at home.
Beat it to fit, Paint it to match... Last edited by Sinister; 01-14-2010 at 01:02 PM. |
01-14-2010, 05:40 PM | #9 |
If ya'll are talking about bearing races (cups?) then they can be removed with a brass punch and a hammer. I have done it many times with great success. Installation is the same way as removal, just backwards. Just keep alternating between sides with the punch when installing and removing.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
01-15-2010, 12:06 AM | #10 |
you can beat the races in and out with a punch, sometimes a scrap 2x4 works good for getting them back in, make sure they go in square!!! there should be a grease seal on the inner again make sure it goes in square or you will be going back to the parts store. just out of curiosity did you check to make sure it's not 1 or both ball joints?
01-15-2010, 02:14 AM | #11 |
Like many others have stated yes you can do this on your own in the comfort of your own shop. Tools you will need - Hammer, Punch (for removal), Brass drift or socket the same diameter as the bearing race that will slide inside the hub with out force (for installation). If you look at the picture to the left, this view is as if you were looking down through the middle of the hub. You will either see or feel two or four divets in the hub that make way for you to place the punch on the bottom edge of the race. If you flip the hub/drum assembly over and look through the other side you will see the other notches for that race. Just place the punch on the race and hit it with the hammer back and forth, you will see the race moving. Once you reach the end it may be neccisary to prop up the drum/hub to give enough clearance for the race to fully be removed. Apon installation simply place the new race in the hub with the dished portion facing up toward you. Take your drift or socket and start tapping in the race until you feel it stop. You will be able to tell when you have reached the bottom lip.
The second pic to the right simply shows in which order everthing goes in. I left out the spindle nut and washer and the dust cap that would normally be pictured at the bottom of that illustration. Hope this helps and good luck. Keep on Truckin!!
- 1967 Chevy C10 shortbox - 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project - 1986 Chevy K10 LWB 350/350 Daily Driver/project |
01-15-2010, 12:12 PM | #12 |
I don't own a brass drift or punch but I have installed many races with a brass bolt. They are cheap and available at most hardware stores. I think their god given intention is to be used to hold the top of your toilet tank to the base. They are soft and bend if you get too agressive with your hammer but in a pinch it will work.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-15-2010, 12:37 PM | #13 |
installing bearing races is made a bit easier by letting them sit in the freezer overnight
01-15-2010, 03:30 PM | #14 |
Buy a bearing race install tool or rent one. I am sure you will use it more than once and the cost is under $50.00.
01-15-2010, 04:55 PM | #15 | |
01-15-2010, 04:55 PM | #16 |
On my '66 I bought new bearings and races (inner/outer) and inner seals from NAPA and they turned the drums and installed the new races and inner seals for a labor cost of $5.00 per drum.
I would also check the ball joints. |
01-15-2010, 05:05 PM | #17 |
I will defiantly look into that, I am sure it would pay for itself over and over vs. the typical hour minimum shop charge. Also I am not the best at being careful with the delicate tapping of things; I’m more the BFH swinging type.
01-15-2010, 05:07 PM | #18 |
You’re saying NAPA did the install of the races and seals? Heck I didn't know they did work on parts.
01-15-2010, 10:01 PM | #19 |
if you have a welder you can weld a bead on the inside of the old race. turn the welder up and go at it. let it cool and turn it over. the race will fall out.
01-15-2010, 10:29 PM | #20 |
01-16-2010, 11:54 AM | #21 |
Chemist under the hood...
My '67 had Timken bearings on the front (inner=LM48548 and outer=LM11949) if that helps. I had to pull out the seals but don't remember having to do anything with the races. I used a seal removal tool and a 2X4 to put them back in. I was able to get OEM GM drums from a dealer (old stock). Wheel cylinders and shoes all replaced and weren't too hard to find.
Make sure you get the spring removal tool and the install tool (two separate tools). i just had the remover and using a screwdriver to put the springs back on caused a lot of hurt fingers!!
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
01-23-2010, 07:29 PM | #22 |
UPDATE. and not good.
First off thank you all for the help, I started the process today, and I have to say it was not that bad, other than this and this is kind of major issue. I knocked out the old sleeves, greased the bearings tapped in the seal and........ The DAMN spindle has a wear spot on the underside that I did not see in my tear down, and since the PO apparently did not use the proper grade grease it wore a minute wear spot that also caused it to swell a bit, just enough for the new bearing not to slide over. So with the new seats in I had to resort to cleaning and re packing the old inner bearing for use as for now. Good news is it doesn’t have movement anymore. I don’t drive very far to work in my truck (about 5 min. each way), but it is every day, so I hope it holds out for now, until the weather warms up so I can finish the other truck. So once again Thank You All….
01-23-2010, 11:38 PM | #23 |
chinese bearings usually slip rite in with a little or no finger pressure, but they fall back out too. Just something to think about
