01-13-2010, 08:22 PM | #1 |
6 mpg... please help
I got a long bed 2wd with a 355 with 305 heads, edelbrock streetmaster intake, edelbrock 500 carb, basicaly stock cam, stock distributor, mallory coil, automatic th350. Its got a 2.73 rear end and 31x10.5s... I know its no honda but I drive a lot and I think I should be gettin a little better milage. Also its real sluggish. Anyone have an idea of what It could be? Thanks guys
"I'll keep my guns, money, and freedom. You can keep the "change" |
01-13-2010, 08:26 PM | #2 |
Re: 6 mpg... please help
the gears and that big tire are killing you. thats why its sluggish. you need to change gears. at least a 3.42 gear with that tire. its a mismatched combo from what you posted.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
01-13-2010, 08:29 PM | #4 |
Ya I lknow it don't help. I had 275 55s on it and I was gettin about7 and I need a new rear end anyways so that's the next thing I'm gettin for it
01-13-2010, 09:11 PM | #5 |
Not sure about compression ratio but its gotta be up there
01-13-2010, 11:32 PM | #6 |
Watchin the rust grow
I'm feeling timing. yeah, the gears suck but I'd check timing, airfilters, plugs and wires, and maybe your driving? I'm not really sure.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
01-14-2010, 02:08 AM | #7 |
yeah check the timing, mine was off by 2 degrees and since i set it to where it needs to be it's freed up the motor and seems like the mileage has improved.
also make sure your tires are aired up to 35-40ish up front and 30-35ish out back (depending on what the tires recommend) and if you were local to me i'd trade you my 3.42's for your 2.73's |
01-14-2010, 03:31 AM | #8 |
put all synthetic fluids in your truck 3:73 rears, od trans new plugs wires check timing, tire pressure and most importantly check your hammer down foot.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
01-14-2010, 05:09 AM | #9 |
BAD BOW-Silverado XST
01-14-2010, 07:14 AM | #10 |
The plugs wires coil cap rotor are like a month old so that's all good. And an OD trans juat aint gonna happen for a while. I usually drive it normal or baby it but sometimes I lay into it.. How hard is it to swap out the gesars or do I have to find a new rear end
01-14-2010, 09:53 AM | #11 | |
Still plays with trucks
You could buy just the gears and carrier from the wrecking yard and do the rest yourself if you are mechanically inclined but it will take a couple hours to complete and won't save you much money. Plus if you get the tolerances wrong setting it up the gears will be noisy or wear out quickly.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-14-2010, 10:04 AM | #12 |
Ok I'm going to call around later for a rear end. Is a rear end with 3.42 or 3.73 hard to find?
01-14-2010, 12:34 PM | #13 | |
Do you have a pull it yourself type junk yard near by? There are currently 26 square body vehicles in the one near me. $85 plus tax for a truck rear end no matter what type or gearing. You just need to find one with the same lug pattern you have to make it a straight swap. You can put six lug axles from your truck into a five lug rear or the other way around too depending upon what you have as long as it is the same type of rear end (12-bolt or 10-bolt).
01-14-2010, 12:56 PM | #14 |
just called a few places> two of them said they have none and two said they got them whatever ratio i can find for 125. and id imagine thats with me pulling it. it that bad? and im getting a vaccuum guage and a timing light soon and going through it all with a freind of mine. the truck starts real fast and easy even when its below zero and runs great. how much diferance will i notice if i go 3.42, or 3.73? will i be able to still take it on the e-way and do the speed limit?
01-14-2010, 01:17 PM | #15 | |
With your 31" tires it will only be at a little over 2400 rpm at 60 mph.
01-14-2010, 01:20 PM | #16 |
I built it
it'll be wound up a little high but you should be able to do 60-65
just make sure you dont get 4.10s!!! like i got.. but i have bigger tires so its like 3.73s with 31s haha (not exactly but close)
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs Last edited by 72chevyk10; 01-14-2010 at 01:22 PM. |
01-14-2010, 01:21 PM | #17 |
The speed limit in michigans 70.. But ill see what I can find. And I thought it was the higher the ratio the worse mileage?
01-14-2010, 02:22 PM | #18 |
I'd kill for 4.10's the 5.13's are brutal without OD.
01-14-2010, 02:25 PM | #19 |
Ya I don't want to go any biger then 373 I'd like to find a 342
01-14-2010, 04:15 PM | #20 |
I built it
yea i can understand that . i had 4.10s 31's and a big block. it prety well toped out at 55mph
id say a 3.42 would be the best for town and freeway. imo anyway
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
01-14-2010, 06:46 PM | #21 |
i like my 3.42's
on the highway at 70ish (i think, no speedo at the moment) it's turning 2500-2600 |
01-14-2010, 07:45 PM | #22 | |
Badass
i got that on mine and the same gears,at 65 its 3100
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
01-14-2010, 07:52 PM | #23 |
A 3.42 gear should have you at 75mph at 3k rpm. if your turning 3100 to go 65mph you have a 3.73 or bigger gear.
01-14-2010, 07:54 PM | #24 |
Badass
no was there when he was putting it in.and counted it.
my speedo was off but we had the gps on and it said 65 at 3k
01-14-2010, 07:58 PM | #25 |
misshape grape
6mpg? even my peterbilt got better than that today at 80k lbs!
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
