Old 01-13-2010, 09:54 PM   #1
thisisdamon
Question Can I set my 72 on a 96 rolling chassis?
Have you ever seen anyone set a 67-72 chevy onto a newer 88-99 rolling chassis? There is only 2.5" difference between the two wheelbases. Sure would be a nice driving truck.
thisisdamon is offline   Reply With Quote
Old 01-13-2010, 09:57 PM   #2
QKENUF4U
QKENUF4U's Avatar
Re: Can I set my 72 on a 96 rolling chassis?
its been discussed... from what ive seen if you make all new body mounts etc. it can be done... but just like anything else.. time, money and know how and ANYTHING CAN BE DONE... sure would be nice ....
QKENUF4U is offline   Reply With Quote
Old 01-13-2010, 10:03 PM   #3
thisisdamon
Smile Re: Can I set my 72 on a 96 rolling chassis?
I'm a welder/fabricator by profession so i have the means and desire to take this on, my main concern is how the frame rails by the front cab corners really seem very different in their curvature. Not sure how much modification would be needed in that area.
Old 01-13-2010, 10:21 PM   #4
Fastfun
Fastfun's Avatar
I think it would be easier to use the 72 frame and put new components on and I think it would be even better handling and ride pretty smooth.
Fastfun is offline   Reply With Quote
Old 01-14-2010, 12:00 AM   #5
CB24
Pave the way bro! If I had the time, money & know how i'd give it a shot.
CB24 is offline   Reply With Quote
Old 01-14-2010, 12:13 AM   #6
63chevyll
gets board easy.......
63chevyll's Avatar
the 88+ trucks have a much wider frame rail. It would be a good build, but a lot of work.
Go for it
63chevyll is offline   Reply With Quote
Old 01-14-2010, 03:55 AM   #7
tomtuna1978
DO IT !!! and take lots of pics and post em !!!
tomtuna1978 is offline   Reply With Quote
Old 01-14-2010, 02:19 PM   #8
jd4300fel
jd4300fel's Avatar
you can do it!! plan it out don't be in a rush. i did something similar. set the cab on jack stands and lots of wood blocks to get the space right. Set the fenders on this will determine if you need to message the fire wall, once you get the front down the back will be a piece of cake. things to remember when you disconnect a wire label it. you can remove them later but for now the more information you have the better. try to have a complete plan before cutting anything. you will also remove the cab alot make sure you have the space to do it. i did mine on a gravel drive that went down hill.
i had the local metal supplier bend up a piece of 1/8 thick steel. then cut this and welded tabs on the side these became my body mounts.
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
Old 01-15-2010, 01:04 AM   #9
thisisdamon
Thanks for the info!
Old 01-15-2010, 06:53 PM   #10
jd4300fel
jd4300fel's Avatar
oh one more point cut the frame horns off the old frame makes mounting the bumper on easier. i made mine smooth due to the width of the frame differences. i could of fabed up some brackets but liked the idea of smooth.
Mike K
Friend of Bill W
Old 01-15-2010, 09:18 PM   #11
thisisdamon
Very good idea my friend, Thanks.
