Old 01-13-2010, 10:12 PM   #1
yellowGT
yellowGT's Avatar
Steering column issue
Not an issue really but more like a question. Is there any way to shorten the steering columns in 67-72. Some of us guys are big or tall and need belly room or arm room so thats why I ask. Cannot stand driving with my elbow bent so much. Shime in if you know of a way.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 01-13-2010, 10:15 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Steering column issue
there is a FAQ re: this. you can drill out the two spots on the collapsible shaft, then with the column loose push is towards the firewall a couple of inches..... the only downfall is that in a wreck it's already partially collapsed..... good luck....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-13-2010, 10:19 PM   #3
JesseH13
AMBITION
JesseH13's Avatar
yeah its not that hard just drill out the 2 on each flat side steering shaft white nylon pins you can see to circles on it and drill out the two nylon pins till theirs no more white then turn it around a do the same then move the neutral safety switch up 2 inchs. and cut in the rectangular hole agian. youull notice it and the steering shaft should move in just put on a vise on on ground get hammer so itll collaspe.
Jesse
1979 Nova-daily-R.I.P
1976 c10 "daily"-
1968 c10 -project
CROOKED68 (PROJECT)
JesseH13 is offline   Reply With Quote
Old 01-15-2010, 01:17 AM   #4
JesseH13
AMBITION
JesseH13's Avatar
heres a pic non tilt...
but still all works.
1976 c10 "daily"-
1968 c10 -project
CROOKED68 (PROJECT)
Old 01-15-2010, 02:21 AM   #5
tomtuna1978
i wonder if you could get the cadilac adjustable steering column and adapt it ? it might take some modifications, but it would be adjustable in and out and up and down. good luck with your quest !
tomtuna1978 is offline   Reply With Quote
