Location: Where I come from, it's cornbread and chicken...
RPO code help
I have some rpo's of the crew cab that I just acquired that I can't figure out...I'm going to list all of them and if anyone knows any, I'll match them to what I have come up with...I don't know if I have all these right or not...this is from research on about 30 different stupid sites...lol...can yall look it over and see what I have wrong and fill in the blanks...thanks fellas
AS3 - SEAT ASM,RR don't know what ASM stands for A52 - SEAT ASM,FRT BENCH B7P - BODY EQUIPMENT,PICKUP BOX PANELS(PRIME) Prime? C6P - 8600 LB GVW C91 - LAMP,DOME D1V - GEAR, SPEEDO DRIVEN D45 - MIRROR,O/S BELOW EYELINE(STNLS STL) E2E - E6D - COUNTRY GAZA wierd, but it's what came up in a search E63 - BODY EQUIPMENT,FLEETSIDE PICKUP BOX E8A - COVER, RR COMPT TONNEAU, RR COMPT - DELETE another wierd one, but it also came up in a search GQ1 - REAR AXLE - STANDARD is this a 14 bolt GT5 - AXLE,RR 4.10 RATIO JB7 - BRAKE SYSTEM,VAC PWR DISC/DRUM K19 - AIR INJECTION SYSTEM is this TBI? K81 - GENERATOR,63 AMP L0T - MX1 - MERCHANDISING OPTION ONLY-DO NOT CATALOG what is this about? M40 - TRANSMISSION,3-SPO AUTO (THM400) NA4 - EMISSION SYSTEM,HEAVY DUTY NA5 - EMISSION SYSTEM,FED REQUIREMENTS NL2 - TANK,AUX FUEL(VAR 2) N41 - STEERING,HYD(VARIABLE RATIO) P10 - CARRIER,SPA TIRE SLK - STL - UN9 - RADIO SUPPRESSION EQUIP UP7 - RADIO,MONUARAL INSTL PROVISIONS MONUARAL INSTL? U37 - LIGHTER,CIGARETTE U69 - RADIO,AM/FM MONO PUSHBUTTON U76 - ANTENNA,W/S EMBEDDED V73 - XYM - LT235/85R16E, R/PE, ST TL ALS BL FRONT what are the letters after the tire size for? YD3 - FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING, GVW PLATE also weird because the truck is 2wd no front axle YD6 - REAR SPRING, BASE EQUIPMENT are these light duty or heavy duty springs? YYN - LT235/85R16E, R/PE ST TL ALS BL REAR what are the letters after the tire size for? ZN3 - ZYN - LT235/85R16E, R/PE ST TL ALS BL SPARE what are the letters after the tire size for? ZY1 - SOLID PAINT Z53 - GAGE.VOLTMETER,OIL PRESS & TEMP 61U - PRIMARY COLOR, EXTERIOR, TAN 62I - INTERIOR TRIM, LT SADDLE 62V - TRIM COMBINATION, VINYL, LT SADDLE Last edited by Stitch; 01-14-2010 at 02:17 AM. |
Re: RPO code help
I'll take a shot:
ASM = abbreviation for "assembly" PRIME = don't know, but it appears that if it is an "unusual" feature then engineering had to tell them to prime/paint it (if that's the case then it apparently was also available "unprimed", and there would be a code for that to balance the release out E6D = could be a country code for Gaza, or perhaps that's just a reference from a different time period from when yours was built. RPO codes do get reused so it could me one thing for a model year and something else for a different model year. For example, my book from 1998 does not show an E6D but it does show an E6E, which is a speedo adapter sleeve. Yours could be in that same family of RPOs. E8A = same as above. GQ1 = just means base (not optional) axle. Ring gear size depends on the model series of the truck. MX1 = a merchandising option is one that functions as a "placeholder" until the specific "purchasable" option can be worked out. For example, you might see "MM4" as a merchandising option for a manual trans, and then the specific manual trans to follow (ie, M20, M62, M64 - particularly when the specific trans will vary based on other option content, as is the case with M62/M64 - same trans but different low gear ratios). K19 - Air injection - is supplemental air shot into the exhaust for emissions purposes (like a California emissions package) UP7 - radio, manaural - should mean "one speaker" Letters after the tire typically designate load range, tire type (ie, all season, on/off road, sidewall type - black wall vs raised white letter or white wall) and other less interesting junk YD3 - you dont' have a front axle? What's keeping the front bumper from dragging on the ground? (I'm kidding of course). That designates the weight capability of the front corners (springs, knuckles) etc which is considered the front axle, even though it is an independent front susp and not a beam type axle YD6 - I'd say those are the base springs. There are separate RPOs (at least two of them) specifically designating HD springs. You might also notice that "X" represents front tire, "Y" for rear tire and "Z" for spare, followed by the specific tire designation "YN". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-14-2010 at 09:04 AM. |
Re: RPO code help
thanks alot Mr. Seymore...I knew you'd chime in with some useful information...
Re: RPO code help
You are welcome (...although I'm still editing...).
![]() I missed the blank ones, cause I was focused on your questions in italics. The only ones I have are L0T - looks like an engine RPO, but I don't recognize it STL - should be "St Louis" V73 - fixed mast radio antenna ZN3 - chassis package, like for Grumman/Winnebago, etc What model year and type of truck are we talking about here, anyway? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-14-2010 at 09:11 AM. |
Re: RPO code help
Not to threadjack, but here goes. Hey keith, I have a 78 C20. It has an engine code of TDS on the build sheet and the Engine block (in front of the head). My RPO sticker says it's an LS9 - 350V8 4bbl. Do you have anything on these engine codes? I can't find that particular code anywhere. the closest I can find is a TSD on an 80-81 chevy van. there's just no TDS anywhere, for any vehicles.
#6 | |
Re: RPO code help
The only link that I have does not show TDS:
http://www.nastyz28.com/gm-chevy-cod...s-suffix-6.php and I did not keep any old literature from back then. Recognize that the "TDS" number is an engine broadcast code, in support of RPO LS9. I tried to describe it like this in the previous thread: Quote:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-14-2010 at 04:12 PM. |
Re: RPO code help
Thanks for the info!
Re: RPO code help
it's an 87 3/4 ton crew cab
I'll pm you the vin if it'll help...thanks again Keith... |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: RPO code help
I'll run the vin at work tomorrow (friday) for ya And try to get a listing of your RPO codes with descriptions.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Re: RPO code help
No luck on running the v.i.n. for ya. Evidently the v.i.n. decoder only goes back to 1989 models. However somewheres around here at home I have a 1990 RPO codes Booklet That might help. I'll see if'n I can find it.
Re: RPO code help
crap...well, thanks for trying at least...I really appreciate it...I'm going to be rebuilding this truck, so it would be good to have as much info as I can on it...thanks again ble 'burban
Re: RPO code help
Try your vin at compnine.com and see if your rpo s show up
#13 |
Re: RPO code help
VIN not found...
