Old 01-14-2010, 10:51 AM   #1
Oldesole7472
What rear gear ratio is good for highway???
My 72 c10's top speed is about 55...i wanna swap the rear with one with a higher ratio...any suggestions???
Oldesole7472 is offline   Reply With Quote
Old 01-14-2010, 11:00 AM   #2
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Re: What rear gear ratio is good for highway???
Mine is tall, 3.07 ratio. I run 75mph at 3k (255/70R15 tire).
That is about as fast as I hold it for long periods of time (traveled this way for 2 years on the interstate from northern to southern Utah during college years).
It would do over 100 if I let it but the motor was singing pretty good.
I just found out last week that my motor isn't a 327, it is a 307ci according to the casting #
Avg of 75mph was getting me 13-14mpg.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 01-14-2010, 11:01 AM   #3
69GMCLonghorn
69GMCLonghorn's Avatar
Well, first of all, get all your information first so you know what you're dealing with:
1) Verify that your speedo is correct.
2) If you don't have a tach, install one and see what your actual RPM is at 55.
3) Figure out what rear end ratio you have now, what tire size, etc. Then do the math and decide what to go with. If you feel it's only comfortable at 55, you'll probably want to go with a 3.08 or 3.42 rear end as long as you don't have an OD tranny.
69GMCLonghorn is offline   Reply With Quote
Old 01-14-2010, 11:09 AM   #4
Oldesole7472
very good ideas...thank you...the engine sounds like its racing @ 60mph but it would he a good idea to get a factual RPM figure before searching for a replacement rear.
What would I look for on the rear that would tell me what i have?
I have 307 CI, 3 on the tree...no OD.
Old 01-14-2010, 11:33 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Surest method is count the teeth on the R & P gears and do the math... but you can jack up the rear, turn a tire one rotation, and count the times the driveshaft rotates.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-14-2010, 11:40 AM   #6
Oldesole7472
thank you very much.
Old 01-14-2010, 11:41 AM   #7
big_al_71
big_al_71's Avatar
3:08 gears would be vote for best highway gears....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-14-2010, 11:50 AM   #8
Oldesole7472
yeah thats what im gonna keep my eye out for...any estimate on how much that swap would cost?
Old 01-14-2010, 12:02 PM   #9
leddzepp
Moderator
leddzepp's Avatar
3.07 would probably be your best bet for highway gears.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 01-14-2010, 02:36 PM   #10
67chevemall
67chevemall's Avatar
I have 3:07's in a box ready to go in....be interested in how much people are paying for the install??
I can't see myself doing it.....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-14-2010, 03:10 PM   #11
GREASEMONKEY72
GREASEMONKEY72's Avatar
mine has the 3.07 rear gear with a turbo 350 tranny and 31in tall tires and it cruises down the freeway under 3grand keeping up with traffic
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-14-2010, 03:30 PM   #12
Sublvr72
Sublvr72's Avatar
with the 350 auto 3.73's were a pretty good gear.
I have a 307 and 3 on the tree in the panel. Haven't taken it on the highway yet, so not sure.
Sublvr72 is offline   Reply With Quote
Old 01-14-2010, 03:32 PM   #13
Ackattack
Ackattack's Avatar
I've found it difficult to acuratly count the teeth on the pinion gear with the differential installed.
Get a tach and do some calculations.
Ackattack is offline   Reply With Quote
Old 01-14-2010, 03:42 PM   #14
70cst
70cst's Avatar
I have 3:73's in conjunction with a 402BB and 400 auto, I am still going to be getting 10-12 mpg.
(I Hope)
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-14-2010, 04:42 PM   #15
1972
Majician
1972's Avatar
To check the ratio, I jack up only 1 rear tire and have a friend spin it 20 times. I get under the truck and use a paint marker to mark the driveshaft, then count the number of times it turns. Divide that number by 10 for your gear ratio.
This method is accurate enough to tell the difference between a 3.50 and 3.55 ratio.
Edit: I know our trucks don't have 3.50 or 3.55 ratios... I was just using those as examples to show the accuracy of this method.
1972 is offline   Reply With Quote
Old 01-14-2010, 04:47 PM   #16
69GMCLonghorn
Gear ratio can be figured out by doing this:
(RPM x Tire Diameter) divided by (MPH x 336)
Old 01-14-2010, 04:51 PM   #17
jholley
jholley's Avatar
I just got my truck back from the shop yesterday. It had a 3.73 open rear. They put in a brand new Eaton Posi, New 3.08 gears, all new bearings inner and outer and did some other odds and ends. It came to around $1500. You could save a lot obviously finding a used one but you never know what youre getting unless you can drive the vehicle it's coming out of. Oh, and I can still turn the tires from a dead stop, only now it's both of them instead of just one. The marks on the pavement are a lot more impressive
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 01-14-2010, 05:07 PM   #18
67chevemall
Makes me remember how BAD I am at math. So simple but it fries my brain
Old 01-14-2010, 05:25 PM   #19
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
your 307 with a 3 speed manual should have a 3.73.
If you can only do 55, you have bigger problems. You should be able to do 100+ MPH.
Old 01-14-2010, 05:30 PM   #20
Oldesole7472
for real? i dont have a tach hooked up but id think that 3rd gear is 1:1 but im far from an expert...actually i dont know much at all about these trucks but thats what my Early Bronco's original 3 spd 3rd gear is...
first gear is high on my c10 but the engine sounds like im racing it anything over 55mph to me...i dunno...im gonna hook up a tach and get some real stats.
Old 01-14-2010, 05:50 PM   #21
Longhorn Man
its one to one.
Old 01-14-2010, 05:55 PM   #22
GREASEMONKEY72
these old trucks make alot noise usually, do hook up a tach to make sure youre not over revving it but i wouldnt be surprised to see that youre only doin about 2500-3000k rpms
-steven
Alte Seele S.S.
Old 01-14-2010, 09:06 PM   #23
chris91
As far as RPM, will a 327 rev higher than a 350? I am wanting to drive my truck on the highway, but it sounds like the engine is revving really high. Maybe I need a tach.
chris91 is offline   Reply With Quote
Old 01-14-2010, 09:54 PM   #24
ERASER5
ERASER5's Avatar
But they can have a 3.54. Some of the Dana 60s came with them.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-14-2010, 09:59 PM   #25
Longhorn Man
You'll be amazed when you put a tach in there. Like mentioned earlier, you're probably just shy of 3000 RPMs on the freeway.
