Tracking Arm/Rearend Question
I've got a 69 C10 shortbed. I took the rearend from a 72 and now it sits almost an inch out the left side. The rear is the same, just 5 lug, but I used the original tracking arm. Anyone ever had this problem? Are the tracking arms different in these year? Any help would be great.
Under Construction
Re: Tracking Arm/Rearend Question
the 68-72 tracking arm were the same. now the 71-72 rear ends are about 3/4 inches wider each side..... they do have adj. track bars as well...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Middle-aged Curmudgeon
I believe there are several different lengths of track bars, depending on what rear end you have and where the anchor points are. I've seen a couple of different frame mounts and then there were several different rear ends.
I went through sort of the same thing-- installed a Dana 60 in place of a 12-bolt. Original track bar wasn't even close to being the same. When hooked up my rear was way out of kilter like yours is. I hunted up a track bar from a 3/4-ton and it wasn't right either (couple of inches too long). I got a big ratchet strap and pulled the body to the center of the rear, measured carefully, then cut the eye off the too-long bar, shortened the rod and welded it back together. Looks factory. There are also adjustable length bars available.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
