Old 01-14-2010, 12:03 PM   #1
cl08
5.3/4L60E Harness Question????
I am wanting to put a 5.3 in a 64 C-10. I am wanting to do a 4L60E or 4L80E for a transmission. What exactly needs to happen for the transmission harness? Do I need an internal or external or both tranny harnesses? Do they need to be modified?
I do not have the 5.3 motor yet. The one I am getting is from a JY 100% complete (accessories, harness, ECM,etc.), BUT I am sure it will not have the transmission harness (at least I dont think it will). I am doing some swapping for a stock 4L60E/4L80E Trans. I am not sure if it will have all the wiring it needs either.
This my first attempt at late model electronics (350/400 bolted to a 700r4 is my knowledge) and I am very neverous trying late model electronics. I know its better and time to move out of the stone age.
I am trying to get everything sorted out before I start buying anything.
I am sorry if I seem very novice in my questions, I am just trying to get all my eggs into a basket. Any response would be greatly appreciated.
cl08 is offline   Reply With Quote
Old 01-14-2010, 12:20 PM   #2
70 Suburban
Rods
Re: 5.3/4L60E Harness Question????
what year is it?
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 01-14-2010, 02:16 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
My .02 is dont worry about the harness at all, just get an aftermarket new harness. It will be alot nicer and not have all the GM crap in there. I know there are alot of people doing the harness themselves too. If you look on EvilBay, search for Stand alone wiring harness, there is one there, also look on LS1Truck.com, very good info, also theileen I think is his handle has a great LS swap page here too. Lots of good info and people to help you.
I did the rework harness and now I wish I would have spent a little more on a new one, it works but isnt very attractive.
Clyde65
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-14-2010, 03:23 PM   #4
tommys66
Unless the JY cuts the transmission harness off of the motor harness, it will be connected with the motor harness. The PCM controls the transmission on these motor/transmission setups, therefore the trans harness is ran thru the motor harness. the only problem you might run into if you do not get a motor and transmission from the same year, is there are a few different speed sensors and Park neutral safety switches.
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 01-14-2010, 03:28 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Sometimes it's easier to get a stand-alone transmission harness/control module that way you can just focus on the correct ECM for the engine type you end up getting. I'm running a CompuShift unit with my 4L80E, but there are others out there from TCI and PCS.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-14-2010, 03:42 PM   #6
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
i am doing this right now i bought an aftermarket harness and it was part of the engine harness as the stock one is it should not be a problem
gostranger is offline   Reply With Quote
Old 01-14-2010, 05:44 PM   #7
63 & 64 Bowties
and a few others
How does the trans know when to shift? I've heard that stand-alone harnesses only work for manual shifting and they have no brake function. Is that true with yours?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-14-2010, 07:24 PM   #8
Clyde65
Clyde65's Avatar
With the stand alone trans controller, it has a little brain that I think you can adjust. With the stand alone harness the PCM does all the thinking after it is programed....Not sure if this is what you asking tho.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-14-2010, 08:51 PM   #9
vin63
vin63's Avatar
The stand-alone controllers operate in the same way as the OE controller - the main harness from the trans, speed sensors, etc, and a throttle position sensor. These aftermarket controllers also allow the user full automatic function to manual shift even with paddle shifters, etc. The TCI and PSC units can be tuned with a PC-based computer (laptop) for a myriad of variables, including shift firmness, etc. The CompuShift that I have has a few user selectable standard programs (for lack of a better term) that address the most common user types. Here are a couple of links...
http://www.hgmelectronics.com/products/compushift
http://www.powertraincontrolsolutions.com/
Old 01-18-2010, 02:33 PM   #10
cl08
What brand of harness are you using? Are you using an aftermarket PCM or stock?
Old 01-18-2010, 05:00 PM   #11
gostranger
gostranger's Avatar
i bought mine from a company called Techrods and paid 456.95 shipped to the door i think i remember buying it through ebay because it was like 100 bux cheaper that way rather than going to there website i did a tone of searching and this was the best buy at the time hope this helps
