Old 01-14-2010, 12:25 PM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
77 3/4 ton brakes
can i take the rear wheel cylinder off my 77 3/4 4 wheel drive with out pulling the axle out? thanks
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
Old 01-14-2010, 03:00 PM   #2
78 Chevyrado
Re: 77 3/4 ton brakes
No. You have to pull the axle out to get the drum off, and you have to get the drum off to disengage the brake shoes from the wheel cylinder.
78 Chevyrado is offline   Reply With Quote
Old 01-14-2010, 08:52 PM   #3
arkracing
Weekend Warrior
only if it is a Full Floater rear end right? The drum should come off of the semi floaters.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 01-15-2010, 01:50 AM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
FF rears will always need to have the axle removed to replace the wheel cylinder.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-15-2010, 11:46 AM   #5
78 Chevyrado
yeah full floaters have to take the axle out, not sure about the semi floaters though, I've never seen one.
Old 01-15-2010, 09:23 PM   #6
wlf89
wlf89's Avatar
ok, thanks guys
69 lwb fleetside
67 swb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
Old 01-15-2010, 11:22 PM   #7
MylilBowTie
Right turn Clyde
If you have a lite duty 3/4 ton it will have semi float rear (most common type). If so the brake drum will come off without removing the axle.
