01-14-2010, 02:46 PM | #1 |
ho52 to 14 bolt
Hi all. I am thinking of swapping out my 72's 3/4 ton ho52 to a 14 bolt rear and seem to remember there are 14 bolts from certain years that will bolt directly in. Does anybody know what years I need to look for??
Thanks |
01-14-2010, 05:26 PM | #2 |
its all about the +6 inches
Re: ho52 to 14 bolt
Is your 72 a 2 wheel drive, or a 4X4?
If it is 2 wheel drive, does it have leafs, or the way more common coils? |
01-14-2010, 05:46 PM | #3 |
Re: ho52 to 14 bolt
Its a 4x4. I have heard it's something like 65 from plate to plate???
01-14-2010, 10:25 PM | #4 |
Re: ho52 to 14 bolt
find a 14 bolt from a 2000+ GM truck. it has an 11.5" ring gear instead of a 10.5" and rear disc brakes! there is a place up here new me (justchevytrucks.com) that deals in these as well as anything else you can think of for a 73+ gm pickup or suv. you may be able to find something more local too. i believe you will need to move the leaf spring perches on any axle not for a 67-72.
01-14-2010, 11:04 PM | #5 |
Rollin Coal
Re: ho52 to 14 bolt
i did that swap in my pickup over the summer(pics coming soon) and i had a mid 70's 14 bolt. ruffstuffspecialties.com has everything you need to put it in, and if you want to, put disc brakes on it
I have three letters to all these import guys: God-Made-Chevy 04 GMC Sierra 2500HD Duramax 1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed 1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's) 1993 Dodge cummins 5-speed DEAD!! Last edited by hicktownhotrodder; 01-14-2010 at 11:05 PM. |
01-16-2010, 01:30 AM | #6 |
Re: ho52 to 14 bolt
i don't think the older 14 bolt is that much better than the HO52....certainly not enough advantage to warrant going through with the swap unless you need a new axle. the late model axle is definitely cool (and beefy) and has the disc brakes. i'm sorry, but i'd rather have well designed factory disc brakes (or even drums) instead of an aftermarket kit that uses car parts and has the lousy e-brake in the caliper instead of a proper separate drum parking brake. those kits are good for show cars and off road vehicles...not my street driven truck that will be towing trailers. i hope to adapt the factory rear disc from a late model 3/4 or 1 ton to the original axle in my 72 burb C20....some day.
01-16-2010, 01:34 AM | #7 | |
Re: ho52 to 14 bolt
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
01-16-2010, 01:39 AM | #8 |
Re: ho52 to 14 bolt
i don't know what you are talking about....
justchevytrucks.com deals in 1973 and newer and they show pics and give info on the axle i mentioned. |
01-16-2010, 03:29 AM | #9 |
Currently Blazerless
Re: ho52 to 14 bolt
Look for a 14 bolt from a 73 up 1 ton, the perch's will be right but you will have to move the shock mounts. I have found some 14 bolt rears from a motor home that bolt right in, shock mounts and all but they are dual wheel..you can still use these just by changing to the single wheel hub and still retain the 13" brakes.
The HO52 is a great axle but the 14 bolt has a few advantages including a much larger and easier to find brake system.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
01-16-2010, 07:28 AM | #10 | |
Re: ho52 to 14 bolt
Fact is,there is no direct bolt-in 14-bolt SRW.But,it`s an easy swap.And remember,rear disc brakes are more hype than anything.More cool factor than a useful upgrade.All drum rears have excellent parking brakes.All heavy trucks have drum brakes.My friend`s`07 K2500 Classic Crewcab Duramax has rear drum.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-16-2010 at 07:32 AM. |
01-16-2010, 11:54 AM | #11 |
Re: ho52 to 14 bolt
AAM is a spin off from GM, and the 14 bolt is the predecessor to the AAM 10.5 and 11.5 that current trucks come with. But the AAM parts are ridiculously expensive compared to the FF 14.
If you have to R&R your HO, the 14 swap is much cheaper, but if you are just "thinking about it 'cause" then don't. One ton 73-91 single rear wheel trucks should have the same spring spacing as a 67-72 4x4 of 40" while the 2x4 trucks are 42.5". It is not very difficult to remove and replace the spring perches. I put a semi-float 14 in my Jimmy and re-used the spring mounts after cutting and moving them. I did however get a set of '72 shock mounts off an old 12 bolt I had as I liked them better. The SF is much beefier and in my case, significantly tighter than the 12 bolt it replaced.
03-17-2010, 03:07 PM | #12 |
Re: ho52 to 14 bolt
Hi all, well my original post and need for an axle swap was based on the need for a new gear ration. I currently have 4:56, but want to changeout to 3:73 for drivability. This is going to be a daily driver and the 4:56 will kill me on gas and rpm's. I am now considering a dana 60 out of a 67-72 3/4 ton gmc. I think this is a direct bolt in, but could be wrong. At least I will have some more options for parts. If I was just going to mud I would leave the ho52 in and just run till I break it.
Thanks for the links and such and if anybody knows of an old gmc sitting around with a rusted dana60 under it give me a shout.
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
