01-14-2010, 08:45 PM | #1 |
Throttle linkage
I'm wondering what you guys are using for throttle linkage. mine doesn't work very well. i have a 350 with an old q-jet. any help is appreciated.
01-14-2010, 09:47 PM | #2 |
It's Better With Nitro
Re: Throttle linkage
I still use the through-firewall pedal and arm assembly, but I made an adjustable link from the arm to the carb from leftover race car throttle linkage shafts and parts I had laying around. I'll try and post some photos this weekend.
01-14-2010, 09:49 PM | #3 |
i still have the arm on the firewall, so i am just wondering what options there are after that. if you have pictures, that would be great. thank you.
01-15-2010, 01:13 PM | #4 |
I found a cool trick on a F**d forum of all places: cut a piece of all-thread from the hardware or home store that will fit your carb fitting, then cut a piece of brake or trans line to slip over it; you'll want to bend them already stuck together if bends are necessary - I found this out the hard way.
Works great for just a few bucks. |
01-15-2010, 01:20 PM | #5 |
Rods
I am goin drive BY wire
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) Last edited by 70 Suburban; 01-15-2010 at 01:26 PM. |
01-15-2010, 01:45 PM | #6 | |
01-15-2010, 03:13 PM | #7 |
i think i also just found out what part of my problem is also. i only have enough throw in the arm on the firewall to get half-throttle when the pedal is to the floor. if i move my carb end of my linkage to the inner position on the carburetor, i should get more movement out of the carburetor. hopefully i can use your picture to help me figure something out.
01-15-2010, 07:42 PM | #8 | |
