62 body lift?
i have been working on my 1962 chevrolet c10 long box over the past year and rebuilt the whole brake system and the engine but i was curious if anybody put a body lift on one of these pickups or was able to somehow lift the suspension without putting a whole lot of money into it and using the original suspension set up instead of converting it or using a different frame. if anybody could help me out it would be much appreciated thanks.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 62 body lift?
Your thread title says 'body lift' but in your post you're talking about suspension lifts. Which do you want to do?
Re: 62 body lift?
i would like to install a body lift preferably but if there is any way to lift the suspension i would look into that as well.
60-66 Nut
Re: 62 body lift?
Well a body lift starts with making lift blocks for all of your body mounts the height you want. Disconnect all linkages, wires and hoses between the body and engine and frame. Then loosen all your body mounts, lift the body and insert your lift blocks. Tighten all the body mounts and then modify all the previously disconnected linkages, wires and hoses so that you can reconnect them.
As for lifting the suspension, the front of a '62 has torsion bars, so they can be adjusted to give a certain amount of increased height. The rear depends on if you have coils or leafs. With leafs you can use a lift block and longer U-bolts as used on 4x4's. With coils the easiest would be taller springs.....if you can find some. Otherwise you may have to move the axle to under the trailing arms. This still requires cutting, welding and some fabrication.
chevy only
![]() Join Date: Sep 2006
Re: 62 body lift?
here is my two wheeler and its bagged
CHEVY ONLY... Nothin Else ! |
Re: 62 body lift?
i really like the look of that. how did you achieve the height in the front end, did you have to modify a lot or were you able to adjust the torsion bars along with some different a-arms? and as for the body lift would i be able to buy a body lift kit for something like an 80's model chevy so i would have polyurethane or nylon lift blocks instead of using square tubing? and would i also have to lower the fan shroud on the radiator instead of cutting the bottom?
Re: 62 body lift?
Man if i ever get a Hot Rod to drive on the weekends I think im gonna raise my truck like this and make it a 4x4 and then it will be a real parts truck!
I cant drive my truck threw a old field and pull a car out with a lowered truck lol that thing would be perfect parts getter or car finder! Man sweet truck looks like lots of work put in to it!!! ![]() And a blast to drive! Looks like you could drive it 100mph off road lol
96 Burban Sold 99 Z71 Sold 65 C10 Sold 72 C10 Sold 87 Short Bed Lowered Daily Driver ![]() http://s623.photobucket.com/albums/tt314/sswagon/ http://www.chevygmcofkc.org/forums/forum.php |
#8 | |
chevy only
Re: 62 body lift?
"Where were you in '62?"
![]() Join Date: Jul 2004
Nice.........
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
Re: 62 body lift?
hey dino can you please go to you CP and grab the link or tell us how to find it most of us can only see 327 or so threads
My son (65gmc930) races a '79 gmc on a short course track up here ,link in sig never mind I did a little diggin and learned something too
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() Last edited by 62gmc910; 01-16-2010 at 01:34 PM. |
#11 | |
chevy only
Re: 62 body lift?
